I have a Compaq computer but cannot get windows started (keeps on booting and booting for ever, safe mode and all other modes dont work).. Pressed F9 for diagnostic and the following details came up as the cause of problem; Drive Error code BIOHD-8, a SMART test failed on the drive. Suggestions: Backup important data/ contact HP support. The software build is 92APheREA1 Any help please?
    President:
  • 3,278 Answers
Hello, Roger.
Sounds like your hard drive is failing.
But, it also could be faulty memory. I'd suggest to remove all your memory modules and reseat (remove and reinsert) one module at a time and reboot.
If there is no difference testing the memory, you'll need to replace your hard drive.
If you are not comfortable "under the hood", please get some assistance.
Hope this helps.
Posted on Feb 08, 2010
Lost my windows vista password
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Oct 18, 2011 | Compaq Presario Notebook
Comes on but only f9 and f10 keys are seen on the screen and a blank screen?
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
Jun 15, 2011 | Compaq Mini 110c-1001NR Notebook
It turns into blue screen with white texts and from below, its says terminating (memory-something) and has a countdown... and reboots itself. computer: Compaq Presario PC SR5050NX
Its probably saying memory dump and the countdown. This is mostly encountered after some kinda change on the pc. It can be new hardware, software or just plain windows update. Lots of times it ends up being a corrupt driver. Try to boot in to safe mode and see doe sit still do same thing. if not than you know it is software related and you can do system restore. To boot in to safe mode on reboot keep on tapping key F8 and choose safe mode. Once in safe mode if it works go to start, all programs, accessories, system tools and choose system recovery. choose like a week back and click next and this will do a restore to when pc was working, fine. If you cant boot into safe mode it is possible it has issues with hardware and this should be checked out by a pc repair shop. Another option you can try if same mode dont work try to do same thing on boot keep on tapping key F8 and instead choosing safe mode try choosing Last Known Good Configuration. this is similar to restore. Hope this helps.
Apr 17, 2011 | Compaq Presario 2200 (292600-004) PC...
I did a system recovery with the cds provided with the laptop for my compaq 2175 but when it restarts it gets stuck on the Windows XP screen and never gets past that point. How do I fix this?
You may have some malfunctioning hardware. When the computer boots up and you see the compaq screen, you should be able to perform hardware diagnostics by pressing one of the F keys. Look in the bottom right hand corner. My guess is going to be malfunctioning hard drive, especially since the computer is a bit "older" and age is rough on laptop hard drives.
I believe the key for diags is F9
Mar 21, 2011 | HP Compaq Presario 2175US Notebook
I need to start my MSI U100 netbook in safemode, I do a hard shutdown and then repeatedly tap F8 while it is starting up. It will not start in safe mode, it simply displays a black screen with "F3....."...
i guess it is a key sequence,all pc 's are different mine goes into bios pages when F2 is pressed whilst booting and F9 when i want to reinstall the OS Dont know why you want "safe" mode or do you mean "standby" whereby you can still download with the lid closed --any how good luck!
Davey Snake!
Oct 20, 2010 | MSI Wind U100-280US Netbook
How to open in safe mode
Turn on the PC - as soon as the BIOS screen dissapears keep tapping
F8 - this will bring up the boot menu and let you select "safe mode".
If you get to the Loading XP screen with the moving bar you pressed F8 too late, reset and try again.
Jan 25, 2010 | Microsoft Windows XP Professional for PC
Powers on ,goes to windows screen and just shows progress bar
Please restart your computer and hit the F8 key before windows loads..then choose safe mode with networking....once in windows click start...run and type "msconfig" go to startup tab and disable everything you dont need to load when windows starts. Then go to the "services" tab...While in the Services tab, you can look at any non-Windows service by left-clicking on the Hide All Microsoft Services checkbox You can also Disable All services if you want to, the reebot normally
Oct 10, 2009 | Dell Computers & Internet
Recently my laptop, lenovo 3000 N100, has a power shortage
if there is a option saying boot in safe mode wtih out networsk try that
also press F8 you will see some extra options try that tooo that will work i did it in a virus affected system
i think the sole reson is some boot files are missing. if the above ones dont work try reinstalling
Jun 17, 2009 | E-Machines eMachines Desktop PC
Compaq Presario 700 PC Notebook ''they keep start up they dont wanna gotrue open the windows'' Problem when shut down when i start up again they keep start up showing the window xp and re start back again...
When turning on the computer keep pressing F8
Select boot into safe mode
Then in safe mode click start then run then type in MSCONFIG
Click on Launch System restore.
Restore your computer to the day beforeyour problem started.
Mar 06, 2009 | Compaq Computers & Internet
Need to reset computer
Hi Emerald20061,
Could you able to boot it in Safe mode.
Tapping F8 Key during Startup. A black screen comes.
Let me know if it works in safe mode. I will suggest you accordingly.
Regards
ELLIN
Sep 16, 2008 | Compaq D51C PC Desktop
Computers & Internet Logo
David Payne
David Payne
