Question about Kenwood HTB-205 System
Kenwood stacker system stereo
Hiya i have a stereo by kenwood everytime i turn it on it says protect and just goes off
  • Anonymous Jun 29, 2008
    i have the same problem with my kenwood v919 xd
  • Hig2 Nov 01, 2008
    that didnt work
Your speaker output is shorting either at the output terminals or at the speaker input . check the cabling . it will solve the problem
Posted on Feb 24, 2008
How do i take my Kenwood car stereo out of protect mode ?
There may be an internal short which will have to be repaired before the radio can be used.
May 25, 2016 | Kenwood Car Audio & Video
When i turn on , the display is" PROTECT " KENWOOD XDA55
make sure the speaker wires aren't shorted anywhere.....a short normally activates protect mode on most stereo systems.
Oct 22, 2010 | Kenwood XD-655 CD Shelf System
My stereo says" protect" everytime i turn it on. can't get anything else.
Hello grammagrisbo, hi your Kenwood head units will show "protect" when there's a problem with the speaker outputs so check to see if the impedance load meets your radio, 8ohms or 4 ohms?. having parallel two speakers on a single channel may cause this dilemma. This might also mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back to normal, the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do something to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. power it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker only. Turn it on again and see if it will displays "protect" message.
If the radio works with one speaker connected, connect the other speaker to the second channel, you may have now the idea where the problem begun, you will identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that channel.
If it displays "protect" with a single speaker connected, then disconnect that one and try the other one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit.
Aug 31, 2010 | Kenwood Car Audio & Video
Kenwood rxd-355
It's a safety measure by design to avoiding overloading your stereo system.
May 31, 2010 | Kenwood Audio Players & Recorders
I have a kenwood stereo and the diplay is reading Protect what do I do? I have the code and it gets approved everytime then just diplays protect right after.
If you have a model with a detachable face there is a reset button under the face. Reset back to original state. If that doesn't work some of the older Kenwoods defaulted to the protect screen whenever there was a 'fault' in the system. ie. a shorted wire or blown speaker.
May 08, 2009 | Car Audio & Video
My kenwood car stereo says protect how do i fix this
well that means you had a safety stereo in the beggining and you proly didnt put the safety code in so it went into secure mode it to prevent the device from working if stollen
Mar 08, 2009 | Car Audio & Video
Protect
The protect message indicates that a problem has been detected in the final output stage of the amplifier. The most common failure parts are the output transistors. Plan on a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Sharp Stereo- Protect Mode??
Try plugging in a pair of headphones. I tried it without the speakers connected and since it found the headphones and they were OK the system came out of protect mode.
Nov 21, 2007 | Kenwood XD-655 CD Shelf System
Kenwood HTB-205 System Logo
218 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
