Question about Vizio GV42L 42 in. LCD Television
Choppy video/sound on HDTV
Hi, I have a Vizio HDTV GV42L and when I am watching HD channels, there are significant slowdowns, the video becomes weird as all kinds of squares show up and the sound is choppy. It's especially bad on CBSHD and ESPNHD. I know there might be a bigger issue because I have a HDTV CRT television in the bedroom and it does the same thing on that TV. Could it be my cable (with Comcast) or could it just simply be the HD channels? Or could it be something else? Please help. Thanks!
2 Suggested Answers
  • 10 Answers
SOURCE: Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Posted on Aug 10, 2009
GV42L vizio tuner
Your vizio has an internal digital tuner. When you are on air, make sure that it is set up for digital. It might say DTV. Some sets have an analog only and digital only program option in the user menu, or as a seperate input. When in doubt, check your user manual.
May 02, 2012 | Vizio GV42L 42 in. LCD Television
Sound is choppy and stops...have to change the channel and go back to old channel for sound to start again?
I have this same issue --- it kinda sounds "digital" or choppy.. then after a few minutes sound will go away all together. If i change the channel the sound returns as normal.
Were you able to fix it?
Jan 24, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a Visio GV42L HDTV loosing sound on some channels
That's a broadcast signal issue not TV issue. If it was the TV all channels would be the same.
Aug 21, 2017 | Televison & Video
I have a vizio vo42l hdtv - the sound and picture mess up
try a new antenna or a signal booster..this will help.. and make sure you have a digital antenna. also try to re-scan the tv because while you scaned it first something was probably not right...hope this helps
Sep 04, 2009 | Vizio GV42L 42 in. LCD Television
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel.  Go into your settings and adjust the h/v settings to move the line off the screen.  You can do this with a combination of v-position or vsize.
Jan 26, 2009 | Vizio GV42L 42 in. LCD Television
Multiple problems with Vizio Galevia GV42L
I have the same problem and it is just livable.  Turn on/off a couple of times and it will be OK.  Interestingly, The Samsung 40" LCD has a powersupply (bad capacitor) problem that seems to mimick this problem  There is a huge thread elsewhere on this Samsung issue, do a search.  Let me know if there is an explicit solution for this.
Nov 14, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42 in. LCD Television Logo
228 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
