Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson my dyson belt has come off how do i get it back on
  • ksgirl2000 Mar 12, 2008
    same issue, how to put the belt back on correctly.
  • 27 Answers
How do you know the belt came off. The Belt has a clutch assembly. It will seem to be off if the machine is in the upright position.
Posted on Feb 23, 2008
you need to lie the dyson out on the floor/table and you will see some screws underneath holding the rotating brush in place, remove these with a torx bit and you will see how it lifts up to allow the belt to be replaced, just keep track of how things sit to make it easier to put back together
Mar 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
How to change the belt on a dyson dc 33
With a small torx driver (not the folding kind, the screw driver kind) and some patience, the belts can be replaced pretty easily. They run about 10 bux for both (you may as well change both). Dyson, like most manufacturers, makes it seem difficult in the hopes that you'll send it back to them for repair, where they will most likely sell you the whole clutch assembly because its easier to replace than fiddling with belts.
Mar 17, 2011 | Dyson DC33 Bagged Upright Vacuum
Changing the belt on a dyson dc17
Here is a link to the belt you need and the manual which has instructions on how to change the belt:
Dyson DC17 Belt and Manual
Dec 24, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i change the belts
you will need to get the special belt tool. they have them on ebey for about $15. enter in "dyson belt tool" into the search engine. don't use your hands as the belt is very tight.
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to replace belt on Dyson DC17
Preface: Dyson folks were great, answer so simple I was embarassed after I called. 5 minute fix.
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Mar 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush on my Dyson DC17 Animal does not turn
Remove the plate over the brushbar. Gently clean out debris. Put plate back on,plug in and turn on vac and press brush bar button to reset.
Mar 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
Feb 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson 07
Start of by laying the machine on its back unfasten the solepate (which is the cover over the brush roll) as soon as its unfastened it will release with ease then you will see the brush roll with the belt around it simply pull the brushroll out of its position and release the belt from the motor spindal (if attached) and then out your new belts around the slot on the brush roll and feed the belt over the motor spindal (this will be very tough to strech on. Once you have done that out the brush roll back in its position and the soleplate back and you should have succesfully fitted a belt to your dyson.
dont forget to rate this post........
Aug 21, 2008 | Dyson DC08 Cylinder Bagless Canister...
Replacements belt for DC 17 absolute animal by dyson
Call Dyson....they sent us ours for free along with a new beater bar
May 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
22 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
