Question about Maytag Dryers
Dryer doesnt work, worked fine a few days ago, checked the circuit breaker, it's fine.
  • 254 Answers
Check the element, thermostats, and themal fuse if not heating...
Posted on Feb 08, 2010
DLE9577SM Power issues. Control board?
  1. Power the dryer OFF and unplug it from the electrical outlet (You can also trip the circuit breaker if that's easier).
  2. Press and hold the START/PAUSE key for 5 seconds while the unit is without power.
  3. Turn the breaker back on, and power on the unit.
Mar 29, 2017 | LG Dryers
Dryer - GE model DRSR483 ED2WW Worked fine a few days ago with a light load. Now, just a loud beep when I try to start it. It doesn't come on. I can turn the drum manually (slowly) - almost sounds like...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | GE DBSR453EBWW Electric Dryer
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
I have an old whirlpoos elec. dryer whilch worked
it could be a broken drum drive belt, or a bad motor or motor start capacitor
Sep 18, 2009 | Whirlpool GEW9250P Electric Dryer
I think rotary start switch just went out
Either your start switch is out or the motor's out. Check the continuity on the switch first. Hope this helps!
Aug 14, 2009 | Dryers
110.67832794 dryer will not heat
Check the thermal fuse. No continuity means a bad fuse. Part costs around 10 bucks no more.
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer
ck door switch also ck connection of power cord could be burnt remove back (if top mount filter lower panel if door mount)look for white thermal fuse ck for closed circuit through fuse fuse is in motor circuit and has been known to blow for pluged or restricted vent system
Jun 10, 2008 | Kenmore Dryers
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Dryers Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
