Question about LG 50PX5D 50 in. Plasma HDTV
Tv turns on stays on sometimes but normally turn back off with in a minute has new power supply
  • LG Master
  • 5,568 Answers
There are probably two supplies in your set; a main power supply and a second one that supplies the high voltage needed by the plasma display. You may have replaced one that was not faulty. It still wouldn't be wasted money if this is true since both supplies are probably of the 'switched mode' type and these can be very reliable if quality components are used which isn't the case in too many.
Posted on Feb 08, 2010
Phillips 50pl9126 rear projection tv. When we turn the tv on it comes on and video and audio are normal. Within about 1 minute the display goes black but the audio stays on. Within 5 seconds or so a...
Have you inspected or changed the lamp? Lamps can slowly break down and not function. Sometimes they will show obvious signs of internal breakage and other times are cloudy or a the base of the center glass filament there will be a bubbling of the glass there. Another problem is there could be an excess of dust accumulated and need to be cleaned out with a vacuum. At any rate, I would recommend changing the lamp first if you haven't done so. There is a access door to the lamp. Some are on the back and some on the front. If the lamp is good the next part is the power supply which will have some bulged capacitors on it keeping the set from starting up normally. If you know how to solder the capacitors are easily identified by a bulge on the top of them. If you cannot solder then changing the power supply is a hand which can be done by unplugging and plugging up another. Do a search online with the model number or call Encompassparts.com at 1-800-638-3328 for price and availability giving them the model number and mentioning the power supply
Dec 10, 2011 | Televison & Video
Toshiba 27af45 repeatedly turns itself off. Sometimes (usually) every few minutes, other times will stay on for hours. Works perfectly otherwise.
The fact that the television stays on for hours and other times turns in five minutes shows that your problem is intermitent .A defective component in the power supply is probaly causing the B plus voltage to go up.The TV can also have a dry joint which looks more likley i am curtain if you gave the TV a firm tap to the side when it come off it would come on back. Try it .
Dec 29, 2010 | Toshiba 27AF45 27" TV
THE tV GOES BLANK WITH NO SOUND 5-10 MINUTES AFTER TURN ON. The blue pilot light in front stays on and sometimes goes yellow . The Tv will sometimes work again if I turn it off and them back on.. Model...
Power supply board is going.Not giving the right voltage to the tv anymore.That why,power it is not consistance.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 26, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
My TV keeps turning off by itself
first you have to open the back cover of the television and check for bulged capacitors if found ,replaced with the same value, but if otherwise,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck...
Jun 07, 2010 | Maxent MX-42XM11 Television
My TV keeps on turning off by itself or will not turn on
The power supply board is defective.The board where the power a/c cord plug into it.That ur power supply board.Replaced the power supply board,ur tv power will return to normal and work as bofore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Tv won't turn on
The tv power supply board is dead,replaced the power supply board should solved this.Tries webstes like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 25, 2010 | Vizio L32 32 in. LCD HDTV
TV won't stay on for more than 10 minutes. Won't turn on at all s
Sounds like a power supply issue. Is it out of warranty? If it is, open it up and check the power supply bd. for swollen capacitors....
Apr 07, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Vizio VO47LF. Sometimes it turns off by
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | Vizio VO47L 47 in. LCD TV
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Tv power intermittant
As computer controlled as TV's are it is a good thing first to unplug the set for 2 minutes then trying operation again.
Feb 03, 2007 | Hitachi 35UX70B 35" TV
LG 50PX5D 50 in. Plasma HDTV Logo
103 people viewed this question
