Question about Kenmore 800 6983 Electric Dryer
Dryer drum does not turn but light and heating element seems to be still in tack
    Sergeant:
    Champion:
  • 263 Answers
Hi My dryer does not get hot. It seems the heating element has blown. It does have a smell to it similar to a hair dryer that has been over worked. I am not sure where to find the heating element to...
It is located in behind the drum.The heat sensor may be also gone and not the heat element.The sensor may be stuck in the spot where it turns of the element.....If u hold a lighter to one it should click to turn the heat element of at a certain temp.Hope this helps u out Ms Young.
Aug 12, 2010 | Maytag PYG4558A Gas Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
My dryer seems to work ok but the heating element doesn't come on.
heating element is out to reach element either remove bottom lid below door you should be able to see element you can see heating coil some are on the back of dryer and some heating are around drum a element may be broken,call repairman
Nov 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Heating element failed twice
most dryers have a thermal fuse on the exhaust it may be open
Mar 17, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Kenmore 800 6983 Electric Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
