Question about Dryers
Dryer drum does not turn but light and heating
Kenmore 80 series dryer
dryer drum does not turn but inside light and heating element seems to be still in tack and pushing heat
    Sergeant:
    Champion:
  • 263 Answers
Kenmore 80's series electric dryer no heat...drum
Check your breaker by turning it off and back on. Then check wiring at plug and back of dryer. You could have a bad relay switch. You can find it under the top and put the 2wires together and try it then . If it works, you know that it is the relay switch. Last but not least, it may be your element. Check it visually to see if there is a break in it or a weak spot.
Feb 27, 2013 | Dryers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
There is no heat in my Kenmore 80 series dryier. The drum is spinning and it seems that there is an air flow coming through, it's just could. The brakers are fine (there are two of them and they are...
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Click on the link below for the details.
Troubleshooting an Electric Dryer Not Heating
Jan 19, 2011 | Kenmore Dryers
No heat, noise when drum turns Sears series 80 electric dryer model # 110.66842501 serial # 11T2010304
Verify that you have 220V ac at the wall . Inspect power cord for damage. Verify that you have 220Vac to the machine.
If you have 220v to the machine then you may have a bad heating element or a loose or bad wire inside the machine.
What kind of noise when drum turns?
I hope this helps. Let me know if I can help in any way.
Mar 22, 2010 | Kenmore Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
Kenmore 80 series stop turning
most likely a bad motor; expensive.
May 19, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Dec 08, 2007 | Kenmore 63942 Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
