Question about Nokia 5310 Cellular Phone
Dosen't display key number 4,5and 6 - Nokia 5310 Cellular Phone
  • 3 Answers
Will i think the keys are messed up just call t-mobile and replace it
Posted on Feb 08, 2010
Misfire on 4,5and 6 cylinders
To be misfiring on all cylinders on one side &
also overheating,I would be checking into a
possible head gasket failure.
You stop using any ford with a flashing mil lamp
on dash or constant misfire code present, or you
ruin first the exhaust converters, then maybe whatever
your current issues are
Jan 22, 2013 | 1999 Ford Explorer
Ribbon doesn't raise up enough to let the letters strike it. Is there an adjustment somewhere?
If it dosen't lift at all wiggle the large black gear bakand forth a few times they do get tooth for tooth.
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
How i set the radio that is lock the code is 0568
The sequence of programming for 1999 Audi A6 radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
Your security code is "0568". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 10 times on the no.# 1 button. The "0" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 5 times on the no.# 2 button. The "5" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 6 times on the no.# 3 button. The "6" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 8 times on the no.# 4 button. The "8" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Mar 31, 2011 | 1999 Audi A6
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
Made a CD from Quicken on a desktop computer and inserted into a Dell Studio Laptop, but unable to remove it. Lost my manual and on checking with store they told me which key to use but it did not work....
pressn the eject key a triangular mark is there on top of the key board.if it dosen;t work, please intall "quick dell" uttility software from "Dell" website.
Sep 05, 2010 | Dell Studio 1537 Laptop
I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A LINE 6. THE BUTTONS FOR THE EXTRA LINES ARE PROGRAM WITH SOMETHING ELSE. HOW DO I PROGRAM THE PHONES TO HAVE LINE 5 AND 6.
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 026(or 032): unassign
repeat the procedure the same as line 5 for line 6
press the release key when finished
Jun 23, 2010 | NorStar M7310 Corded Phone
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Apr 23, 2009 | Minolta Office Equipment & Supplies
Minolta Di183 display shows 88
2 Making sure that “U--” appears on
the Display, enter “5” from the 10-
Key Pad.
Enter the 6-digit administrator
? Do you know how to enter the
administrator number?
➜ Enter the six digits successively.
? Do you want to correct a wrong
number just entered?
➜ Press the [Clear] key and then
enter the correct number.
6 Check that “Ad-” appears on the
Display.
7
Enter the code assigned to the
desired subfunction from the 10-
Key Pad.
? Do you know the code for Copy
Track?
➜ To select Copy Track, enter “1.”
? Do you know the code for Disable Auto Shut OFF?
➜ To select Disable Auto Shut OFF, enter “2.”
8 Press the [Start] key.
GO to Konicaminolta US website down load a operators manual free
Jan 26, 2009 | Minolta DiALTA Di183 Copier
Nokia 5310 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
