Question about Ovens
Ge electric oven not working. displaying a s8 code? Model number 326b1230p001
    Sergeant:
    Champion:
  • 263 Answers
F8 means main board failure. The model number you gave is no good.
oven repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 20, 2009 | GE Ovens
Microwave display just flashed F6 error code. Only mention in manual is for lower oven display.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and remind us that it displayed an F6 error code.
Nov 26, 2009 | GE JKP85 Electric Double Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 30, 2009 | GE JTP45 Electric Double Oven
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
326B1230P001 GE double oven
You can go to http://www3.sears.com/ or http://www.appliancepartspros.com/. You will need the complete model # from the sticker on the oven. The # listed above is not correct. It looks like a serial #.
Nov 06, 2007 | GE JTP20 Electric Single Oven
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
Ovens Logo
233 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
