Question about Canon SPEEDLITE 580EX TTL Flash
Everything seems to be working with my Canon580EX but it just won't fire.
    Champion:
  • 254 Answers
Jackie,
Try shorting out center pin to outside lead, this will fire the flash. If not, flashtube or trigger maybe bad.
atdlee@netzero.com
Posted on Feb 15, 2010
  • 3 Answers
Do you mean you can also use the E-ttl functions and all others special funtions ?
Mine isn't firing, and for exemple the zoom function doesn't work with my lenses ( compatible lenses, including the zoom datas).
Do you have the same problem ?
KR
Posted on Mar 30, 2010
The air con won't work. How do I fix it, everything seems to be set up fine. I thought all I had to do was turn it on and the air con would turn on, but it won't
Check that the master switch on the external condenser fan housing is turned on, it is a sliding button like switch.
Feb 25, 2013 | Heating & Cooling
94 volvo 960 wagon engine turns over but it won't
have you check for injector pulse? if no pulse or no ignition fire, most likely it is the ECM.
Jun 13, 2012 | Cars & Trucks
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
I had to take out my carver 3600 stc gas fire out now it won't light
seems confusion recheck everything and put it once by once together
Apr 15, 2012 | Audio Players & Recorders
Can anyone help. ive got a hilti dx450 that won't fire, ive stripped it down and given it a good clean but still no luck getting it to work. could anyone tell me if there should be some sort of firing...
You are correct on the firing pin. Those rim fire caps have to be struck by a firing pin or it won't fire. Pull the head apart and see is the firing pin stuck or missing.
Oct 03, 2017 | Cars & Trucks
Electrical - won't start. Hooked up fan to heater, smoke came out from under the hood, car won't start. Lights work, any key related electrical functions won't work
Your fan or heater likely shorted out and burned up, causing your one of the main fuses to blow due to the spike in current. You will need to determine what burnt up and replace it before replacing the fuse, or you may create a fire hazard or cause further equipment damage. Also double check any changes to wiring to make sure that everything is hooked up properly.
Nov 01, 2011 | 1991 Chevrolet Cavalier
Canon SPEEDLITE 580EX TTL Flash Logo
765 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
