Question about Car Audio & Video
I AHVE A HD PHILIPS TV ,IHAVE ABSOLUTLEY NO SOUND ON THE STANDARD TV ,I ONLYHAVE SOUND IF I PLAY A DVD MOVIE. RIGHT NOW THE SUPERBOWL IS ON AND I CANT HEAR A THING.PLEASEHELP.
  • 518 Answers
When you play a dvd, do you have to select aux, or video channel to play this ? if so select tv on your remote, not a solution, just an idea.
Posted on Feb 08, 2010
SOURCE:
Connected PC to LG with HDMI. Wonderful pic but NO sound. PC HDMI audio test works great and sound is clear thru TV. When movie is played from PC to TV there is no sound.
How do you get HDMI out to tv, through a graphics card? Is Is it HDMI direct out of the card or DVI adaptor? I believe you will get a ping even if the volume is turned down and when playing a movie you would have volume control throuh the DVD player, the computer and the tv. Make sure your volume is turned up on dvd player and right click on your speaker icon in taskbar, at lower right of screen and make sure that volume is up. When you do the ping are you checking a "HD" audio driver. Look in 'device manager" in "sound audio and game controllers" and right click on "HD" devices and make sure they are enabled. Let me know what happens. When you look at devices in device manager you also may see a warning. If so click on the symbol, ? ,!, or triangle and follow proceedure.
Dave
Apr 06, 2011 | LG 42LC2D 42 in. LCD HDTV
Sony tv will play copies of movies from tv, but won't play store bought new ones. I mean current popular ones. It played Avatar last week but won't now. We tried several new movies and none will play. Put...
There is some confusion in the explanation here.
The TV does not play movies it displays them It is the DVD that Plays them. But of course you knew that. Some of the newer movies like avatarcan be on Blu ray if your DVD is supposed to play Blu ray but doesn't don't be surprised as they have changed the format recently. Your DVD will require an udate of firmnware. Go to the website of the DVD brand and contact support Download the update and burn it to a disc and run it.
With the TV end Make sure the resolution can be accepted from the DVD you are trying to Play. If it isn't HD or capable of 1024x768 at 16.4 then it may not be able to display the image. Is there any sound?
If sound but no Pic then start playing with the picture format. go to 8.2 or 4,0 to see if it makes any difference
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Televison & Video
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
Cannot get the visual from the videos
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jun 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Playing movies through usb port?
The options when you play a DVD it will appear when you are connecting ext HD it will not work.
Better you need the play in a DVD Disc to get the good sound.
Jan 06, 2009 | Philips HTS3440/37 System
I need help! Our cable jack on our tv is messed up so we have to run it through a dvd/vhs player. I have tried everything to get it to work. I can play dvds and see them, but i cant get the satellite to...
Change the source on the Philips/Magnavox to switch between satellite and movies (warning: this particular Philips/Mag cannot process HD Satellite receiver boxes). You can switch sources by using the Magnavox remote and pressing 0-2. Then press ch down until the display says either L1 or L2 - whichever input the satellite is connected to. Another warning: For my instructions to work, you must have a non-HD satellite receiver, and you must run a red, white and yellow cable from the satellite box to the Magnavox instead of a standard coaxial cable wire (and then, of course, run a second set of red, white and yellow cables from the Magnavox to your TV).
-Tha Mp3 Doctor
Dec 31, 2008 | Philips Magnavox DVD/VCR Dual Player
PHILIPS TV SOUND PROBLEM
My phillips tv model # 55pl9773/17 sound is too low when im watching regular tv, but when i switch from tv to av1 or av2 (watching a dvd movie or playing video games) the sound is normal. How do i get my cable TV to sound the same?
Sep 28, 2008 | Televison & Video
I can't record a movie from the DirecTV HD
You would have to connect a red, white and yellow cable from the outputs of the DirecTV box to the section marked AV IN on the back of the Philips. Then change the channel on the Philips to E1. Press play on the DirecTV box, and press Record on the Philips.
-Tha Mp3 Doctor
Aug 10, 2008 | Philips DVDR3505/37 DVD Recorder
VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Dec 17, 2007 | LG 42LC2D 42 in. LCD HDTV
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
