Question about Boating
Motor dies once it gets warm. running ethenol regular gas. starts easily and runs good until the motor gets plenty warm....20 minutes or 1/2 hour. has new spark plug. pushing a 12' jon boat in small lake for trolling.
    Top Expert:
  • 46,271 Answers
Sounds like you need to replace water pump .trolling slow it should never get hot .
Posted on Apr 26, 2010
Motor cycle starts once it is warmed up stalls out
Have the carburetors serviced. Sounds like a fuel pump problem(if your bike has one). If not it is because the idle mix is too lean.
Mar 30, 2014 | 2001 Suzuki GSX 750 F (Katana)
1991 Ford F-350 runs rough at cold start, dies if gas peddle depressed?
If you have a carb its chock .If injection its fuel related filters regulator restrictions if fuel flow ect.
Sep 11, 2017 | 1991 Chevrolet C1500
because the combustion inside the engine is going wrong the quantity of air getting inside is not the needed quantity maybe less than or more in cold will cause such problem once the engine warm up than the engine temperature is up you will not find this problem because the point of firing will be near
Jan 02, 2014 | 1991 Chevrolet C1500
Is high-octane gas killing my older engine?
The gas is not the problem. You have problems with the engine and related control system.
Feb 27, 2017 | Chevrolet G30 Cars & Trucks
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
1996 plymouth neon 2.0 sohc starts up fine, runs good untill it warms up about 20 min, to 1/2 hour then starts losing power, starts spiting and spudering and when giving gas wants to quit? then it...
well its a long shot but it could be your catalytic converter is going bad or is clogged, i have seen them get so hott they glow red. this sometimes can be seen at night by looking under your car after it has ran to the point of stalling and dieing,, if thats the problem the car cant exhaust creating back pressure that robbs power and can cause your car to die.. after it cools the metal shrinks back and the car will runn again untill it getts hott.. i hope this helps
Jun 01, 2011 | 1996 Plymouth Neon
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Boating Logo
172 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
