Question about Mirage BPSS 210 Speaker
Internal damage to Mirage BPSS-210 Subwoofer amp
I had a Mirage BPSS-210 sub connected to a Mirage LFX-3 controller, the rotary pots for the shape control LP and HP on the LFX-3 are acting up to where when adjusted the sub makes very loud pop type noises and adjusting them ended up hurting the sub, it blew a couple of fuses at first and now the sub still plays but within 10 minutes at any volume the subs heat sinks get very hot when it never barely got warm under any circumstances in the past.
Any ideas on what got toasted in the subs amp section.
Also I have 2 other BPSS-210 subs and they work fine also I tried connecting the bad subs amp to another BPSS-210 and had the same bad result so it appears to be in this particular subs amp.
  • 32 Answers
Something getting hot probably means something shorted out. You probably know that since you replaced the fuses already... . Can you give me some idea of what you do and do not know about electronics? Then I will say fewer dumb things. . When troubleshooting any electronic device, especially amps, open it up and look at the circuit board. Look for burned board and components. Then test to see if the burned/blown component had reason to blow (it probably did). . Often a shorted transistor runs too much current through some other component and the other component blows up. . Another cause, less common, is a shorted cap. . Look at the schematics if you have them, if not, you may have to create one to make sense of it. . Or take it to a shop where somebody does this all the time. The only one here went belly up in the last 12 months... . . About the pots . Try blowing out the pots which are popping with some tuner cleaner. Use with caution, and always with everything turned off and power cords unplugged. . Pots do not usually make popping noises unless they are very old or live in a very dusty place... . I found the manual, but no schematics... http://docs.google.com/viewer?a=v&q=cache:9Doi39-AcW0J:www.miragespeakers.com/images/download/374.aspx+Mirage+BPSS-210+schematic&hl=en&gl=us&pid=bl&srcid=ADGEESjBKgLSTb8wp5SRWIOWd-gE0INdBXbfz5QDNJ_3esye4_R2Q9aKba8cEePSWQWOebeXB9zXnJSelIel2bLSR5q6KExe8MVjOk1zqFKk4K-ruti_797yf1Ig3CIcUNjE49jx8DAr&sig=AHIEtbS6udedt_o6GqL7ALPunU0v3vMvuw . You might be able to get better, more exacting help on the Mirage Forum... http://community.miragespeakers.com/forums/ But maybe not, since the Subwoofer section gets less than one post per month, and the much busier Technical Questions section only has 23 in the last 12 months.
Posted on Feb 08, 2010
Where can i get a replacement amplifier for mirage mm6 subwoofer?
You can try to contact Mirage to get info on where to get a new amp module http://www.autonomic-controls.com/products_hardware_mirage_audio_system.php. However if you have solder experiance you can change the 3 small electrolytic capasitors C6, C7 & C8 that are glued down in the middle of the mainboard. That should bring back life to your sub.
Jul 20, 2014 | Mirage MM6 Speaker
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
I have a velodyne f-1200r how do I hook up to other speakers
The simplest way is to connect both the left and right channel speaker wires from your amp or receiver into the speaker wire connections on the back of the sub labeled "From Amplifier"
Then connect speaker wires from the adjacent terminals labeled "To Speakers"
What you are essentially doing now is using the internal crossover of the subwoofer where you determine at what frequency the sub begins to blend with the other speakers.
This is done with the Crossover knob just above the speaker wire connections.
Whatever you have this set to, the main volume will now raise and lower the volume of the sub and main speaker together but you can still make the sub louder or softer as compared to the main speakers by using the subs volume control.
Defeat all tone controls on your preamp or receiver and use only the crossover knob and sub volume until you achieve a seamless blend where you cannot tell where the sub is and it is an extension of the speakers from where you will be sitting.
TIP:
DO not evaluate from the sub itself because the room shape and acoustics are drastically different everywhere ESPECIALLY when you are dealing with bass frequencies.
Can I assume you know how to set this?
May 31, 2014 | Audio Players & Recorders
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
I do not see any inputs to connect a subwoofer to my Onkyo A-9555 integrated amp. I would like to know if it is possible to connect it and what kind of subwoofer should I buy for that wit the best...
You amp has no OUTputs for a sub, but if you really want to attach a sub you'll need to get one that is self-amplified and accepts >>>stereo<<< High Level or Speaker Level inputs.
Otherwise your amp's volume control won't also control the sub's volume.
You would feed it full-range audio from the speaker terminals on your amp and its internal amp would use that to develop its own power output for the sub.
Here's one example.
http://www.ch.onkyo.com/files.download/skw-205_manual_e.pdf
Jan 29, 2011 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Shortcut in the tranfo. where do I get a new?
look for a compatible on ebay or o to hifi shop
Oct 30, 2010 | Mirage BPSS 210 Speaker
Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Mar 04, 2010 | Mirage LF150 Subwoofer
I plug in small speaker but only faint sound come out are the speaker output also amplfied pb10 230
Depends on what, if anything, is connected to the High Level speaker inputs. The High Level outputs only pass on what is being fed to the Sub from your amplifier or receiver. The sub's internal amp is for its use ONLY.
If you're using the Sub's internal amplifier and feeding it the LFE or Subwoofer Line Level output of your amp or receiver via RCA cables, I'd be surprised if anything is present at the speaker terminals on the sub. It shouldn't be.
Mar 04, 2010 | JBL PB10 Subwoofer
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
455 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
Rob
Rob
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
