Question about Toshiba Satellite P30 P35 Series Notebook
Motherboard for Toshiba Satellite P30
My Toshiba Satellite P30 Laptop is not working properly. It get hang after approx 5 to 10 min. after switching on. Then I have to switch off by holding power button; It switches on after some time only but behaves the same way. It showed me the error 'Media feluer' in blue screen. My current location is Mumbai, India. So I took the machine to HCL Infosystems Ltd; After a week they told me the problem of motherboard. They said I need to replace it but they do not have this specific motherboard (Processor type: Intel Pentium 4 processor, clock speed 33.32 GHz). How can bye the same motherboard? And what will be the cost?
    Scholar:
  • 103 Answers
Hi friend check this website out here is a price and repair company you could send it to. link.http://product.pelltechnology.com/Toshiba_Satellite_P30-S701TD_Motherboard_Replacement.asp
copy and paste
Posted on Feb 22, 2008
  • Jason bates
    Jason bates Feb 22, 2008
    you rated this as inappropriate why? you asked where you could get a motherboard and i sent you a link. isnt that what you wanted?
Toshiba satellite p30 no display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 18, 2012 | Toshiba Satellite P30 P35 Series Notebook
My Toshiba laptop hangs in 2 -3 mins of starting
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084
Apr 12, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite P30 (new) Battery (and old) not charging
Your charging circuitry, inside the PC may be faulty. OR maybe the Power Adapter, you need to try another adapter, if the problem does not go away, then you have an internal motherboard power supply problem it will have to be serviced. Or just maybe the second battery is faulty too, unlikely.
Mar 26, 2010 | Toshiba Satellite P30-S701TD Notebook
My Toshiba Satellite PC hangs when I insert any USB device
To reinstall USB drivers, you need to reinstall the system, as USB root hub drivers are built in on Windows.
Tray first removing laptop battery and unplugging AC charger for ten or fifteen minutes, this will get rid of static charges that can cause USB not to work.
If that does not solve the problem then you need to reinstall Windows, in this case, try a system restore first.
If all that still does not work, then there is an hardware fault, in that case you often need to replace the motherboard.
Jan 02, 2009 | Toshiba Satellite A105 Notebook
Easy keys
you need to download the value added package on toshiba support website support.toshiba.com
paste here your part # and i can give you the link on the said program
Sep 18, 2008 | Toshiba Satellite P30 Notebook
Toshiba satellite L30 PLS30L-00M00D
Please go to the below link and select the type of operating system you are using and download the drivers. Hopefully it should work.
"http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp?service=EU"
Thank you..
Sep 10, 2008 | Toshiba Satellite P30 P35 Series Notebook
DC JACK FOR Toshiba Satellite P35-S611
You will need a small set of screwdrivers, flathead and phillips, a pair of pliers or nut drivers, and a soldiering iron. A magnetic screw tray is also handy with all the small screws. You will need to completely disassemble the machine and remove the motherboard. If replacing with a new jack you will then need to heat up the soldier holding the jack in place to remove the old jack, then heat and clean out the old soldier from the hole the jack pins fit into. Soldier the new jack into place and put it all back together. I believe the P30 and P35 are basically the same machine, here's a link to disassembly instructions for the P30.
http://www.irisvista.com/tech/laptops/ToshibaP30/SatelliteP30_disassemble_laptop_1.htm
Jul 24, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite p30 133
possibly memory chip or hard drive failure,
swap ram chips around to see if that fixes it .
if you have the ability, try the drive in another pc,it will not boot fully but you will be able to tell if it is working ok, else it looks like a service on the cards.
good luck
Terry
Mar 25, 2008 | Computers & Internet
Motherboard for Satellite P30-149 P4 538/XP
If you want to buy this replacement Mother Board, contact Toshiba. If you need help replacing it, let us know and we can direct you from there. If you are having a problem with and upgrade or a component on this Mother Board, please give us more detailed information on what your problem is.
Thanks, and Good luck.
Feb 22, 2008 | Toshiba Satellite P30 P35 Series Notebook
Computer has no sound at all
do you have audio drivers installed? you can try here http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp they have 3 kinds of p30 and i of course dont know which one you have so what you want to do is select portables->satellite->(whatever p30 you have) then click go then finally go to downloads and search for your sound drivers
Sep 28, 2007 | Toshiba Satellite P30 P35 Series Notebook
Toshiba Satellite P30 P35 Series Notebook Logo
645 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
