Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Blurry images at the edges, double image picture, slightly out of focus.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 10, 2010
When I take a picture it always comes out blurry. How do I correct this?
Search Results
    The Top 4 Causes of Blurry Photos, And How To Fix Them ...
    www.digital-photo-secrets.com/.../the-top-4-causes-of-blurry-photos-and...
    Out of focus An image that is out of focus will appear blurry. ... The first is to increase the shutter speed as explained above, The second is to hold your camera steady whileyou take the shot. .... It's always very helpful, and I enjoyed the video.
    Why Do My Pictures Come Out So Blurry? « Samsung Galaxy S3
Nov 30, 2015 | Cameras
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
Image in the viewfinder appears blurry
you have adjust diaptor wheel acoording to your eye setting. adjust your camera according to this sujetion you want get blurry picture.
you can get this diaptor wheel next to view finder.
May 23, 2010 | Canon EOS 450D Digital Camera
Image on Monitor is slightly blurry
Try reducing the screen resolution to 1/2 of what it is now!
Jan 20, 2010 | Acer AL1916W 19" LCD Monitor
Problem with image
Stars are blurry period thats just the way they are. and with the worlds atmosphere (air) you'll always get a slight waviness...even when viewing planets.
Sep 14, 2009 | Edu-Science (10166) Telescope
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
Blurry picture
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
Jan 01, 2009 | Radio Shack VGA PC Camera Webcam
Focusing problems
Hello Samaro,
This effect is produced when the tho sides of the binoculars are not focusing the same.
Since you sayit is present at long distance, it might be that one barrel is stuck and is not focusing the same as the otherone when you scroll the middle "focuser".
What you can do is open it up and try to clean it, also see if there is something, that is making one of the lenses not move forward as far as the other one.
Good luck,
Dahaka
Jul 28, 2008 | Fujinon CD Binocular
Which lens
Hey caturner7,
If you have a large family and you are having a difficult time fitting everyone in the frame then a wide angle lens might be exactly what you need, but this will probably not make your images any sharper. The most common cause of blurry images is the camera is moving during exposure. Even the slightest camera shake can cause blurry images. There are multiple solutions to this, first make sure the shutter speed is high enough, then make sure the ISO is set to about 400, and then make sure the flash is on. Another cause of this could be that the camera is not achieving focus so make sure you are pressing the shutter button down halfway so the camera can achieve focus before you take the picture. A slightly telephoto lens usually produces the most pleasing portraits. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 03, 2008 | Cameras
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
296 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
