My PC randomly starts to beep continuously. I say randomly as it can start beeping at anytime, including when the computer is switched off and not being used. I can pull out the power cable and the beeping continues. However, if I pull out the LAN cable it stops. Any ideas? Thanks.
  • 1 more comment
  • David Feb 10, 2010
    Hi Mike, running Vista and the "Beep" doesn't show up. Would it be somewhere else. Thanks
  • David Feb 11, 2010
    Hi. This gets weirder. This morning the beeping started again. Computer had been off all night. After checking each connnection, I discovered that the beeping stops when the graphic card plug is removed. Take it out the beeping dies down. Put it back in the beeping comes back on. This happens regardless if the power cord is connected or not. However, if I leave the graphic card plug out for more than 10 seconds and put it back in, the beeping doesn't start again. I'll run a spare g card for awhile and see if that is the problem. But, the beeping happening without power is weird. The "Beep" option doesn't show up in Vista Premium.
  • David Feb 19, 2010
    Hi Mike. Re-seated the graphics card and changed all the power connectors and it seems to have worked. Thanks for your help.
    President:
  • 2,351 Answers
Try replacing the RJ45 LAN cable. It may have a short in it. Also check the metal back plate. Each opening has small 1 or 2 tabs that ground each port.
The MB's internal speaker must have power in order to beep. Since you have pulled out the power cable there can't be any Standby power to the MB which keeps the cmos battery charged while the system is off. However every RJ45 does carry a low amount of voltage through the cable. If the above doesn't help there is one other thing you can do;
Go to Device Manager and "Show Hidden Devices".
Under "Non-Plug and Play Drivers" you'll see an item named "Beep".
Disable that and the "random beeps" disappears.
Once done, of course, you can hide the hidden devices again.
Cheers'
Mike
Posted on Feb 08, 2010
Testimonial: "Thanks for the help."
  • 1 more comment
  • Mike Peluso
    Mike Peluso Feb 11, 2010
    For windows Vista;
    Open Device Manager by left clicking the Start button, than left clicking Control Panel, than clicking System and Maintenance, and then clicking Device Manager. If you are prompted for an administrator password or confirmation, type the password or provide confirmation if asked for. Follow the instruction from my last post. Open the link provided below for Vista;
    http://www.vista4beginners.com/Disable-S...
    Hope you find this helpful!
    Mike
  • Mike Peluso
    Mike Peluso Feb 12, 2010
    dverted2, here at FixYa answering questions can be troublesome.
    Every system is different. We prefer posters to include the basic hardware within their systems. This includes, operating system, motherboard model and manufactures name, add on graphics cards model number and power supply wattage. With respect to you're system. When a system boots up and one hears continues repeating beeps and their using a PCI-E or AGP graphics card that requires external power to function properly. Normally the bios sends out the repeating beep that’s telling you the graphics card needs external power connected. Make sure you're current video card is receiving the proper external power cable. (You're system beeps are being generated by the bios) The bios maintains an average of 3 to 2.5 volts DC. More than enough power for the bios to beep error’s.
  • Mike Peluso
    It’s possible that the power cable being used is not fully connected to the power port on the video card. Its also possible for 1 or more wires within the power cable is loose. You're power supply should have more than 1 graphics card power cable. Try another power cable.
    Mike
Computer won't start at all - continuous long beeps
One long beep probably indicates that the memory chip(s) are not inserted properly.
Jan 19, 2014 | Acer Aspire E700 PC Desktop
Computer won't start continuous long beeps
Probably means the memory chip(s) are not inserted properly
My Dell Inspiron 530 won't start. 4 Beeps, Soild blue light.
According to Dell this is a RAM issue. You can find a list of diagnostic Beep Codes here. Also be sure to inspect the capacitors on your motherboard. If you notice any of them leaking or blown then that is your problem.
If you have extra RAM lying around then swap it into your PC and see if you're having the same problem. If not, pull out any unnecessary RAM just to test it. There are four RAM slots on this PC and you should be able to use any one of them. If your PC turns on then you can isolate which chip is giving you problems. Keep in mind RAM is ideally installed in matched pairs.
If you only have one RAM chip in your computer then I'm afraid you will either have to buy another one or borrow one from a friend to test. Shouldn't be too expensive anyway.
Jul 24, 2012 | Dell Inspiron 530 Desktop Computer
Steady continuous beeps & computer doesnt boot..?
Its mostly an RAM problem, you need to check you PC RAM. Also use a sytem utility software RegInOut to optimize your PC. RegInOut is a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of Internet Optimizer enhance users web browsing experience.
Dec 15, 2011 | Lenovo 3000 J205 PC Desktop
My Humax PVR has started beeping - what does this mean, can it be fixed
Hi Ruthie:
Hard to tell without further information, pvr model, how is hooked up.
But, couple of guesses.
Have you updated the firmware?
Is it losing signal?
Usually, a beep is a warning signal for something.
Kinda like on a computer when it beeps when it starts.
It has a series of different beeps to let you know whats
going on. Is it continuous beeping or random ?
I have looked at a owners manual for a Humax and did not
see any reference to "beeps".
You may want to email Humax support for an answer.
Don't forget to put in your model number and connections.
The more information you give them the easier your problem
will be for them to fix...sorry for the long post.
Good Luck...if I find anything, I'll let you know.
Dec 27, 2010 | Humax Televison & Video
Long beep problem when I turned on my computer
Not the right category for computer but a beeping computer on switch on usually means the memory module is not present or not working.
A continuing beep beep beep memory missing.
One long continues beep that stops and the computer then works could be anything normally the PC is looking for something can’t fined it and moves on.
If you are concerned restore the system to a previous time i.e., prior to the beep starting to happen.
Sep 13, 2010 | Home
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Desktop freezes up so often or gets logout by itself & reboot?!
This could be a couple of things, overheating may cause it to randomly shut down, but if it freezes up on you then it could be a motherboard issue or memory. When you boot up your computer, does it beep at you at all? More than 1 beep signifies a problem. Right click on the my computer icon and click properties, see how much memory it says you have, does that number look accurate? A bad memory module could cause similar problems. A bad motherboard would, in my experience, more often freeze when you first boot up.
Mar 12, 2009 | Computers & Internet
Beeping when I turn on me computer
The POST (power on self test) is failing which is why the pc is beeping. As stated by knotbeerdan, I would need to know how many beeps. Most of the time it's either something laying on the keyboard pushing doewn on the jeys, the keyboard is unplugged, or it could be completely different. I would say the reason it's restarting itself is the power supply is going bad. Typically that's the issue when they restart, though at times it could be something else causing it.
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Random series of beeps from Gateway 300C
How many beeps do you get, this is very important to your solution.
Nov 08, 2008 | Gateway 300 C PC Desktop
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
