Question about Gigabyte GA-K8VM800M Motherboard
GA-810 gigabyte motherboard
When i go to reboot it gives out 3 beeps any idea ????
  • 167 Answers
It can be graphic card or memory! Try to reboot first without memory if beep try then it graphic card damaged!!
Good luck
Posted on Feb 22, 2008
GA-H77M-D3H 6 beeps on POST and then restarts
Check timing between each beep---Make sure It's 6 Even beeps--Not 3+3--1+5--2+4 ect----Timing between beeps will tell you---let me know.
Mar 01, 2014 | Gigabyte GA-H77M-D3H Socket 1155/ Intel...
Computer was shut down abnormally following a power failure in a thunder storm. No apparent physical damage to machine but will not reboot. Machine gives single long beeps at 6 second intervals. BIOS is...
take out the processor chip and clock battery along with the ram while it is disconnected from the wall outlet and wait about 5 mins. after you put it back together, if the problem persists the processor might need to be replaced or the entire motherboard its self.
Jun 28, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
GigaByte GA-8EGXR-P motherboard beeps when turned on - no video or BIOS - system does not boot
hi try to clean memory ram....clean it using eraser.....most of motherboard beep if memory not detected....or try other memory ram
May 10, 2011 | Gigabyte GA-8EGXDR-EL Motherboard
GA-MA790GP-DS4H doesn't boot. It gives 14 short
Hello my friend,
There is no way to have 15 beeps error especially short ones so
First try to count the beeps and if are long or short
Jan 29, 2010 | Gigabyte Computers & Internet
Pc just doesnt boot or give any beeps. Helpp???
i have 3 pc,s from rebuilds that all do this its nearly always a motherboard failure try removing c/mos battery or trying a different power supply you may get lucky.
Jan 20, 2010 | Gigabyte GA-M61VME-S2 Motherboard
I need audio driver Gigabyte GA K8VM800M" Can you give me ?
No, we cant. But Gigabyte can.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1919
Apr 19, 2009 | Gigabyte GA-K8VM800M Motherboard
MOTHERBOARD GA-7ZX THE PROBLEM IS , I HAVE A MOTHERBOARD GA-7ZX,WITH VGA ON BOARD AND IN YOUR MANUALS , THERE IS NOTHER ABOUT THIS MODEL AS I SAID MOTHER BOARD GA-7ZX, ALL YOUR VER. IS MENTIONED THAT MODEL...
You posted this problem twice. I have replied to each differently.
The motherboard manuals would be supplied by the manufacturer, in this case a company named Gigabyte, which is not a part of nor related in any way to FixYa.com website. The following is a link to the support page for this motherboard on the Gigabyte website:)
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1369
There are three revisions of this motherboard {1.x, 5.0 and 5.1} and NONE of them have onboard VGA. All use an add-in 4X AGP VGA card that goes into the brown slot at the top of the white PCI slots.
Compare your motherboard to the pictures available at Gigabytes' support page (the link above) to make sure we are talking about the same motherboard, although as far as I can see there was no other manufacturer that made a motherboard with the GA-7ZX designation. Please verify and repost your results.
Jan 09, 2009 | Gigabyte GA-7ZX Motherboard
Repeating beep on startup.
Hi iamborg,
You're Gigabyte GA-8VD667K board uses an Award bios. (Click on the link).
http://www.bioscentral.com/beepcodes/awardbeep.htm
The beeps are telling you to remove you're memory & seseat it.
It would help if you cleaned the copper colored contacts with some house hold alchhol on a cotton swap. (clean both sides & let dry).
Good Luck!
That should do it.
Mike
May 03, 2008 | Gigabyte GA-8VD667K Motherboard
Reboot
There can be problem with memory or your graphic card!
When you next time reboot pull out memory if beep then it's the problem with you graphic card!!!
good luck
Feb 22, 2008 | Gigabyte GA-K8VM800M Motherboard
AGP card support
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in Intel® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
Aug 19, 2007 | Gigabyte GA-8I845GV-C (GBSA4LB)...
Gigabyte GA-K8VM800M Motherboard Logo
87 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
