Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
It won't spray solution and the water comes out slow or very little?
  • 17 Answers
Here is the solution
Posted on Feb 08, 2010
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat 2 x won't spray water
PLEASE GO TO THE PAGE FOR TROUBLESHOOTING AND HELP
http://www.bissell.com/how-to-videos/
God bless you
Jul 23, 2012 | Bissell Vacuums
My bissell proheat 2 x won't spray water or vacuum water
please go to the web pages videos for troubleshooting and help:
God bless you
Jul 23, 2012 | Vacuums
Rubbermaid reveal mop won't spray
I know this question is a little old... but I had the same problem and I figured it out! Unscrew the red top to the bottle. Under the top there is a gasket (leave that alone) and a little clear plastic plug blocking an air hole. Pull the little plug out and put it back in the holder. (Be careful, liquid will come out of the hole). This allows for air and cleaner to flow through.. so viola! It's spraying! I was so mad when it didn't work (brand new). I wish it had come with this little tip on the packaging! Have fun! :)
Jan 04, 2012 | Rubbermaid Vacuums
My bissell proheat pet won't spray through the bottom. the tools work but not the floor cleaning part.
This worked for ours it had alot of little crystallized pieces in the valve cleaned it not water will come out bottom. Thanks!
Oct 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
I also had the same problem as you.
Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
I did this a couple of times and it worked. This info I found on the Bissell website.
Good Luck!
Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Will not spray
I have the same problem. I took it apart and found that the water pump had leaked and burned out the water pump motor. It's a $20 part.
Aug 16, 2007 | Bissell 1425 Little Green ProHeat Handheld...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
101 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
