Ty so much fredinot. i think u are exactly right. How do I uniinstall old driver in control panel. This was the one that had file corruption with static on my webcam- jack thx again
  • 1 more comment
  • calahara22 Feb 08, 2010
    hello . I have already uninstalled these programs and reinstalled them. Is that the same as drivers? It still does not work, and I know there is file corruption on driver or webcam. How do I fix this problem. Do i just uninstall programs associated with webcam? How is uninstalling driver different. I know that file corruption is prolem- thx for your help
    like I said before. I have already uninstalled programs and reinstalled them, and restarted. This did not fix problem, but one tech suggested uninstalling old driver, and installing cd driver again for my camera
    how do I do a system restore? you think that is my best option, I was considering doin multiple reboots inbetween installation and reinstallation, before I only do this once I think. one tech recommend that. Sytem restore sounds the easiest way, but i would like ur opinion on which to do. How do I know what drivers are associated with webcams???????????. thx - p.s. not important drivers are the same as programs or what?
    President:
  • 2,923 Answers
To uninstall the driver, click the "Add or Remove" program (for Win XP) or "Programs and Feature" (for Win Vista).
The window will be populated with the list of drivers that are currently installed in your computer. Find the driver that you would like to delete or uninstall, click it once and then click the "Remove" or "Uninstall" button. You will see the progress of removing the driver.
Good luck and have a good evening!
Posted on Feb 08, 2010
Testimonial: "it is good, but still have problem "
  • Melvin Ramos
    Melvin Ramos Feb 08, 2010
    That could be possible. Having similar drivers in one computer is possible. Unfortunately, there's no other place to go to in deleting the driver aside from "Add or Remove Program" or "Programs and Features".
    But if you could not completely delete the driver, what you could do is to remember when the driver was installed and then perform a System Restore on the day before the driver installation was done.
    Doing it would surely delete the old driver. However, any program that was installed in between the day of the driver was installed up to the present would be deleted.
    But System Restore would be your last option. Try to delete every driver that is associated with the Web cam and see if that helps.
    Thank you and good luck!
  • Melvin Ramos
    Once you load the CD that came with the camera, you will see the name of the driver that's about to install. All related programs is under the same name.
    To perform a System Restore, please follow the steps below:
    * Start > All Programs > Accessories > System Tools > System Restore.
    Again, you will be ask to go back or to select the date when you would like the most recent time the computer worked correctly. All applications (not files) that were installed in between the said date up to the present would be deleted.
    Thank you for the response!
IERTUTIL.ACER
1) go to control panel see the icon SOUND, and see the troubleshooting, and use.
2) go to control panel and use the device manager, and see if there are some yellow interrogation if there are, the problem is driven missing or corrupted. Go to the website supplier and download the driver in according with the model. uninstal the old one, and install the new driver update.
3) you can go too control panel, use the system restore, and go to some date that you know the sound was working good, and fix it.
God bless you
Jul 05, 2013 | Computers & Internet
I change my old mouse to ibm usb, but the installation had an error, i don't remember exactly the error occured but i remember that it stated there windowns 95.. my OS is windows xp sp3, i've been...
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
if you need any more help with this post a reply
hope this helps
Aug 13, 2011 | Computers & Internet
Seems to be a corrupted set of files in one of my folders. Looks like wingdings, can't open anything
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver:
another?thing you could try?is to click start control panel administrive tools computer management disk management right click on your drive select? properties
tools check now tick in both boxes to scan for and attempt repair/recover any bad sectors and automatically fix any corrupt files
or you might tick in one box wait until it has finished then return at tick the other box
hope this helps
Jul 22, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My card reader is not detected by my computer
is it a usb device
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jul 03, 2011 | Computers & Internet
Having problems with finding the SM Bus Controller Driver for my hp pavilion a1200y.. motherboard Asterope-GL8E. any help would be great
click start control panel administrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or
if you can see the drive and its not working right click to update drivers also you might try
click start control panel administrive tools computer management disc management if you can see your drive right click select properties tools check now tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
hope this helps
Apr 21, 2011 | Compaq (261671-001) Motherboard
The screen read B81AA198. And now, the printer is not operating. Why?
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
dont forget to vote
Feb 03, 2011 | Computers & Internet
Installed windows 7 all audio drivers are working, but no sound what could be wrong?
the drivers might have been corrupted by a virus or something foreign to your system run your antivirus program
then go to control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow ? question mark right click to update driver or
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
If the ntdll.dll error only displays when you use a specific software program,
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
hope this helps
Dec 22, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I have no sound and have run a hardware diognostics scan. The outcome is that there is an error in c:windowssystem32drivers vmfdx32.sys . I have been trying to find a download to fix this. Dont no a lot...
Your drivers for this computer somehow got corrupted, so pull out the installation discs that came with your computer.  You will have to do a search on these discs to find the system 32 driver file.  Then you copy and paste the file onto your hard drive directory to replace the old corrupted file.  See how that works for you old chap.
Cheers
Nov 04, 2009 | Cell Phones
Usb problem
Is this problem occurring every time? If its first time then i would advice to format Pen drive . Yes if files are corrupted then in properties windows of pen drive its show data empty. Try to format.
Sep 22, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Crystal eyes webcam
OK REMOVE OLD DRIVERS AND REINSTALL LATEST DRIVER.ENABLE CAM AND REBOOT DRIVERS SHOULD LOAD AND FIX THISPROBLEM.RICHARDM69
Dec 02, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
David Payne
David Payne
