Question about Whirlpool Duet GHW9150P Front Load Washer
We have a leak in the drum of the washer. Very
We have a leak in the drum of the washer. From Saturday last week to the next Saturday there was enough water to spill out when we opened the door.
    Sergeant:
    Champion:
  • 263 Answers
Doesn't dry clothes in spin cycle- spins but not enough
so it is the spin cycle that does not work that is the drum does not turn. Have you tried other levels such as delicate wash and see if spin works. LASTLY, disconnect power and reconnect.
Mar 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
2003 bmw 320d smoking exhaust did run out of diesel last week driving to italy saturday think its ok
chances are you picked up some s..t from the bottom of the tank,use some injector cleaner when you next top up with diesel,should clear the smoking problem.
Feb 23, 2011 | 1999 BMW 3 Series
My LG front load washer is leaking during the rinse cycle. I cleaned the filter and it is still leaking. What should I do?
Leakage can be a few things..Check the door boot seal for any small rips, next the fill hoses are the watertight, next drain hose , now under the machine is the pump ok, Last assuming all hoses are ok has the drum a hole in it...good luck
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Kenmore washer started making banging noise in last spain cycle. Now unable to spinn drum by hand.
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Mar 20, 2010 | Kenmore 24902 Top Load Washer
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
268 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
