Wall stained form storage heaters - Heating & Cooling
2 Suggested Answers
SOURCE: wall mounted dimplex night storage heater
WHATS THE QUESTION?
Posted on Feb 25, 2012
How do I wire FOR STORAGE HEATING
230volt is gonna require a double pole breaker, not single phase. Makes sense with 2kw.
If that's the case, then you'll have 2 hot wires & a ground.
Feb 16, 2015 | Heating & Cooling
Why are this walls stand
Hi Carl
It looks like staining we used to get from air blowers that were used to heat the room.
Is that a hot air vent I can see running along the base of the wall? If so it looks like either dirt from an unfiltered blower or some mild scorching of the wall covering from the long term hot air blowing past it.
Feb 27, 2013 | Heating & Cooling
Need to replace front of storage drawer
Instead of replacing the door of the storage drawer, can you please use some chemicals which will remove the bad stains. Make sure you use chemicals which will not affect the steel. Lots of chemicals available in the market to remove bad stains for steel.
Thanks.
Mar 31, 2012 | Refrigerators
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
I need to replace some old storage heaters in my
you need to measure the height of celing size of room how many outside walls thickness of walls take this info to your local heating shop they will tell you the heat loss for each room and what size heating you need in kws you then choose the heaters you want
Apr 19, 2010 | Heating & Cooling
I have a creda storage heater 79153, i turned it on on sunday night monday morning it was still cold , i changed the fuse at the wall still nothing, the only part that works is the convector heater at the...
Check the fuse board it should be marked up (but often is not especially if POLISH electricians concerned) it should be a 32 amp fuse.
The heater has a thermal fuse installed internally £12 replacement, these tend to be the only things that go wrong with storage heaters! get a qualified electrician who you trust to have a look otherwise who-ever looks at it will say its F****d and will take you to the cleaners
Oct 21, 2009 | Heating & Cooling
I have black soot on my walls from my baseboard heaters, is this hazardous or dangerous to my health?
same issue years ago. these heaters draw air in from the bottom and push it out the top. so any dirty air (candles burning will do it) is pulled through the heater and pushed out the top causing stains on walls.
Jan 01, 2009 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
