The manual for the indoor units says MSZ-A09NA or A15NA or A12NA or A17 NA. The left indicator (green) light is blinking and I have no heat. I have tried switching the breaker on and off and I have tried the emergency operation for heat and I still end up with the same situation.
  • jseegal Feb 08, 2010
    I used the remote to turn on one unit and the left indicator light blinked once per second for about 3 minutes, so I stopped counting. I can't see that option in them manual. The outdoor model is MXZ-3A30NA; I didn't notice the header on my request for help that listed different model number until it was too late to correct it. This problem began when I went out to the condenser to remove snow around it (we have a blizzard). The fan stopped while I was out there, started very briefly without the same oomph, then stopped. It doesn't seem to be ice- or snow-bound. I may have tilted the condenser when I climbed over it, but I've got it level again, at least on one side.
  • 43,501 Answers
The green blinking light is telling you a code to tell you what is wrong with your unit. To figure out the code you need to time the blinks and how many...
To decipher the code then you need this service manual..
The troubleshooting part of the manual starts on page 22 you can download the manual and then figure out what is going on with your unit.
http://www.mrslim.com/UploadedFiles/Resource/MSZ-FD09~12NA_Service_Manual_OBH497C_12-01-08.pdf
Heatman101
Posted on Feb 08, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Feb 08, 2010
    A few more things that you can do and check...
    Make sure that the outdoor fan is free and can turn easily.
    Remove the power from the outdoor unit for a few minutes and then restore the power and see if it comes on..
    In moving the unit, you may have a wire that came off at the outdoor unit. This seems unlikely because you have power on the indoor unit and that power comes from the outdoor unit. However there is one wire that is just communication to the indoor unit and if that wire happeneed to come loose then you would being having your problems...
    These units are usually super dependable, so I agree with you athat whatever happened probably was weather related.
    Heatman101
I have a Mitsubishi Mr. Slim Model MSZ-A09NA. We just purchased the house and have only been using it for a week. I had it serviced on Friday and was told it worked fine. Sat. we had a power outage. ...
Hi, it sounds like you may have lost the blower motor due to the power surge. Normally, it would kick the breaker off.The code is just telling you something is not right as you know. You can try turning off the breaker to the indoor unit for 10 minutes or so, and reset it to see if the blower will start. If you have the manual, that might tell you what the code or light is. Its more then likely a 220 volt indoor unit. Sometimes on a double pole breaker, only one half of it will trip in a power surge. Check to see if this is the case, as you may only be getting 120 volts to run the vanes. If its half way tripped, turn it off hard, and back on hard. that may be your problem. If not, call the service tech, and just tell him it stopped working. He will come out at know charge to you. I bet its your breaker though. Please let me know.
Sincerely,
Shastalaker7
A/C Contractor
Jun 06, 2011 | Mitsubishi MS09TW Air Conditioner
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
We have a msz-ga80va split cycle, indoor unit runs for about 5 minutes without cooling then cuts out, outside unit doesn't kick in at all
Just had the same thing happen to us with the same model (right on Xmas day).
Checked the circuit breaker is on in the fuse box. Power is on to the external unit. Filters are clean.
Internal unit activates... both indicator lights on. After 5 minutes blowing air it stops and the right indicator light goes out and the left indicator light blinks constantly.
The troubleshooting guide inside the internal unit (under the outer cover you open to clean the filters) suggests that 14 blinks is an abnormality with the external unit and refer to service manual.
Think we'll be calling a technician.
Dec 26, 2010 | Mitsubishi Heating & Cooling
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
How to turn heat on for split system MSZ GE 12NA
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Nov 06, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
We have a far-let LED flashing 1 second on 1 second off repeatedly indicating a communication error between the indoor and outdoor units. The practical outcome is that the outside condenser doesn't kick...
Call Mitsubishi Tech. directly...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
heatman101
Sep 03, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
