Question about Makita Drills
How do I change the chuck on my Makita cordless drill
  • 2,176 Answers
Go to the tip section and you will find detailed instructions on how to do this or go to my profile and you should find it there also.
Posted on Feb 11, 2010
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
rowdy45176
  • 2176 Answers
SOURCE: changing a drill chuck
If this is a cordless drill open chuck jaws and remove the retaining screw (LH trheads), switch the clutch to drill only and shift gear selector to low. Insert a bent handle allen wrench about the same size as chuck (to keep from flexing) put chuck on workbench or block of wood and have the wrench about 30 degrees and strike the key counterclockwise to remove. You might have to hit a couple times but usually they will loosen up quickly. To install just reverse above. Let me know if I can help further.
Dave
Posted on Dec 26, 2008
rowdy45176
  • 2176 Answers
SOURCE: Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Posted on Dec 31, 2008
gisvc
  • 40 Answers
SOURCE: How do i get the chuck off a makita cordless drill
HI,
Most hand-held drills have chucks that screw onto the shaft with a right-hand thread. Reversible drills lock the chuck in place with a left-hand threaded screw inside the chuck. To remove this screw, open the jaws of the chuck all the way and use a screwdriver to back out the screw (turning it clockwise, of course, to loosen it). The easiest way to get the chuck off, once the screw is out, is to chuck the short end of a large Allen wrench into the drill, run the drill backwards at low speed, and let the long end of the Allen wrench bang into a concrete floor or a 2x4 or something until you hear a pop and the chuck just screws off. The impacts seem to loosen stuck threads very well. The problem with my drill was that my clutch was damaged and I couldn't get enough of an impact to loosen the threads. I had to get to the clutch before I could get to the chuck.
HOPE THIS HELPS!
Posted on Mar 30, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
I want to replace the chuck on my Makita 6280d 14.4v cordless drill. Help please........
The chuck may have a left hand screw insde and at bottom of chuck, some chucks scew on and the screw holds it in place, may have to put an allen wrench in chuck and hit the wrench with hammer one way or the other to losen it.
Dec 29, 2010 | Makita 6280DWPE 14.4V 3/8" Driver - Drill...
I can't get the drill bit out of My Makita 6333D cordless hand drill. I usually have no problem. I did tighten the chuck pretty tight, but now can't loosen it. Help.
put the drill in a vise and using a pair of channel lock pliers grip the chuck and it should come loose will a little tug on the pliers
Sep 12, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Changing a drill chuck
Dave
Dec 25, 2008 | Makita Drills
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
174 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
