Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
The left indicator light is blinking and I have no heat. I have tried turning the breaker off and on and I have tried emergency heat setup and I still end up with the same problem
Turn the whole unit off at the circuit breakers. Let it completely defrost. I left mine off for two days until the outside weather improved. When I turned the circuit back on, it was fine.
Posted on Mar 04, 2010
My Maytag MDB6160AWW finished its last cycle with a blinking "clean" light. I didn't think much of it. And somehow cleared the lights. When I filled it up and wanted to start a wash it will light up,
Blinking clean light is an error code does it blink 7 time pause then repeat that would be a heat circuit problem fast blinking a stuck key behind the lower panel should be a tech sheet explaining how to determine what the code is
Dec 24, 2014 | Maytag Dishwashers
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
Defrost & power lights are blinking, Unit does not heat.
Heat pumps are only good above certain temps, like mentioned. Then usually heater coils come on if the unit has them. It may not. Check the manual, or Google the make and model for a user manual. Make sure all your breakers are on all the way, not tripped. A tripped one will be a little away from on, turn it all the way off and then on again.
Nov 24, 2013 | Heating & Cooling
My left & right indicator does not work & does not blink when it's on.. how do i fix it?
There could be several things that will cause your blinkers to stop working. Most will have to be diagnosed by a QUALIFIED automotive electrical shop but there is one thing you can try first. Step one is to turn your blinker stalk rapidly between right and left turn. Don't damage anything, just go back and forth several times real fast. Next, turn your emergency flashers on and off. Rapidly, like you did with the turn signal stalk. Again, don't damage anything, just do it as rapidly as you can, several times. What you are trying to do is clean the contacts inside the switches. Those two circuits work together to operate the turn signal lights and the emergency flashers are rarely, if ever, used and the contacts get a little corroded.
Nov 22, 2010 | 1991 Daihatsu Charade
I have a 1993 VW Passat VR6, My problem is when I try to start it, I have no spark from the spark plugs..What could be the problem or how do I fix this?????
GO TO THIS SiTE TO CHECK THE FUSE BOX!
http://vwtech.no-ip.info/images/golf/post90.gif
This are the FUSE and RELAY number SLOT!
Fuse No. Description Ampere Rating 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Glove compartment light 15 5 Wiper/washer 15 6 Fresh air blower 16-valve only: Air conditioning 20 7 Taillights, side marker light, right 10 8 Taillights, side marker light, left 0 9 Rear window defogger 20 10 2.0 16-valve only: Fog lights 15 11 Headlight, high beam, left,High beam indicator light 10 12 Headlight, high beam, right 10 13 Horn 16-valve only: Radiator cooling fan 10 14 Back-up lights, washer nozzle heaters 10 15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10 16 Instrument panel warning lights, 16-valve only: Multi function indicator 15 17 Emergency flasher switch, turn signals 10 18 Fuel pump, oxygen sensor heater 20 19 Radiator cooling fan, air conditioning 30 20 Brake lights, cruise control 10 21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15 22 Radio, cigarette lighter 10
Relays Relay No. Description 1 Air conditioning 2 Open 3 Digifant control unit 4 Load reduction relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Rear Wiper 8 Intermittent wipers 9 Seat belt warning system control unit (possibly headlight warning too?) 10 Fog lights 11 Horn 12 Fuel pump (except diesel)Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay 14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run 15 ABS pump relay 16 ABS relay 17 Heated seat control unit, driver 18 Heated seat control unit, passenger, or power seat circuit breaker 19 Automatic transmission 20 Open 21 Power window relay, ABS hydraulic pump fuse 22 ABS valves fuse 23 Air conditioning, power seat fuse 24 Power window fuse
Nov 17, 2010 | 1993 Volkswagen Passat
How do fix turn signals on buic regal 1996?
It helps if you describe the problem. Does not blink? blinks fast? indicator stays on? right or left? both? do the emergency blinkers work ok? Parking lights work? brake lights?
Mar 19, 2010 | 1996 Buick Regal Olympic Gold
When i press the emergency light button - only the light on right side start blinking. The light bulbs are okay as my indicators are working fine. Is there a fuse that has gone bad or some other issue?...
check the fusebox first to make sure a fuse hasnt blown,then try the relay for the indicators/hazard lights.if you havent got a circuit tester,this will be trial/error.
Feb 22, 2010 | 2000 Audi A4
Furnance will not come on
No Blink? no call for heat. Check thermostat. Jump out thermostat. Check the fuse in the cabinet as well as in the breaker box. Do you have an emergency switch that may have been turned off? Make sure the door interlock switch is closed and working.
Jan 29, 2009 | Goodman GMS90703BXA Heater
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
290 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
