Question about ATI ASUS P5RD1-V RADEON XPRESS 200 CHIPSET SATA150 ATX FORM FACTOR 1xPCI-E(X16)/3xPCI-E(X1)/3xPCI/4x... (MBP5RD1) Motherboard
No bios, no beeps ASUS P5RD1-V
If you can assist thankyou.
My pc stopped working. I get no beeps and a blank screen. I checked the memory, changed the cmos battery and cleared it, tried both video cards, swapped power suppy and nothing.
I see the light on for the wake on lan, i hear the hard drive, fan for the cpu turns on,fan on the video card turns on as well. I tried the onboard video plus 3 other video cards.
I tested the monitor on another pc and it works.
It sounds like the pc turns on but no bios comes up and no beeps sound.
If i press the power button on for about 5 seconds the pc shuts off.
If i remove the fan that sits on the of the cpu then i hear a few clicks and then the pc shuts off.
Anybody know what could be wrong?
Seems like the mother board has juice but i don't see what can be wrong.
Thanks in advance
  • 4 Answers
I have the same problem although mine came when I used a Linux HDD cloning tool and next thing the PC would not start at all, I am not sure if it just coincidently died at when I rebooted or if it lost the Bios or something due to the cloning I tried.
The Cloning was on 2 USB drives and the internal HDD was and is still disconnected and the 2 USB drives are removed, still same behavior.
Posted on Jun 04, 2010
  • 96 Answers
Yes thats a motherboard problem. Try to migrate your system with another board and test. That signs really is from a defective motheboard.
Posted on Feb 07, 2010
Asus 1015cx will not boot at all
I would open it up, remove the hard drive and memory. Then see if you can get into the BIOS. Then put back the memory and try again.. Do you hear any beeps at startup?
Mar 08, 2014 | ASUS Eee PC 1015Cx
I can't boot from sata CDs with my motherboard asus p5rd1
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS recovery
hope this helps you
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
May 08, 2010 | ASUS P5RD1-VM Motherboard
P5rd1-vm - will RAID setting delete my data
Suggest you enter the bios and make a setting change. Open the manual to page 2-24.
The M1573 RAID function set this to [Disabled].
(This will stop the bios from loading the RAID controller.)
See boot menu page 2-31 section 2.6
Set section 2.6.1 Boot device priority as shown.
(The drive with windows installation on it should be in the boot order).
You can also unplug either the data cable or power cable of the slave drive to assure it does not boot. If you still receive a blue screen with the primary drive suggest you re-install windows or boot to the windows CD and create a new partition within the free space of the primary drive. Install windows complete including updating. When finished you'll be able to copy you're data to the new windows. Use windows disk manger program (diskmgmt.msc) in the run window to delete the old windows partition.
Some programs will need to be reinstalled.
Link to Asus; http://www.asus.com/Search.aspx?SearchKey=P5RD1-VM
Cheers'
Mike
Mar 14, 2010 | ASUS P5RD1-VM Motherboard
ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Jul 21, 2009 | ASUS P5S800-VM Motherboard
No bios beep no work
ok u can remove your ram and clean and than after same things u can change your ram and see.. and also u can change your bios cell.This RAM problem that's why ok.
Mar 28, 2009 | Computers & Internet
Wont boot up
You could be using the wrong type of memory. Check your mobo specs to see what your mobo is compatible with.
Oct 23, 2008 | ASUS P5RD1-VM Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Wont boot just has series of beeps
Table 2. System Beep Codes
Beep Code Possible Cause Corrective Action
1 Memory refresh failure Reseat the DIMMs.
2 Parity cannot be reset Reseat the DIMMs.
3 Memory failure within the first 64 KB of memory Reseat the DIMMs.
4 Timer not operational See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
5 Processor failure See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
6 8442 keyboard controller error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
7 Processor exception error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
8 Video display memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
9 Optional ROM checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
10 CMOS memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
11 BIOS checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
Jan 11, 2008 | ASUS K8V-MX Motherboard
ATI ASUS P5RD1-V RADEON XPRESS 200 CHIPSET SATA150 ATX FORM FACTOR 1xPCI-E(X16)/3xPCI-E(X1)/3xPCI/4x... (MBP5RD1) Motherboard Logo
194 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
