Question about Whirlpool Ovens
Oven temperture calibration on RF378LXPT - Whirlpool Ovens
  • 254 Answers
Check ur manual, if dont have go to whirlpool.com and go to thier manuals and literature section to download or print a copy out, most calibration is done through the electronic display, hope this helps
Posted on Feb 08, 2010
No temperature control on hot plate elements. Is this fixable?
ADJUST OVEN FLAME LEVEL: Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat. The reason for my free advice is GOD is good!
Dec 16, 2016 | Ovens
Where is the oven sensor temperture located
typically a metal probe on the inside of the oven. you may be able to search an appliance part website for you oven model number and see part breakdown diagram.
Mar 28, 2012 | Ovens
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
CANNOT FIGURE OUT HOW TO CALIBRATE THE OVEN. OVEN TEMPERATURE IS OFF 50 DEGREES. INSTALLED A NEW THERMACOUPLE. THIS DID NOT HELP THE PEOBLEM. OVEN WAS PURCHASED IN 1992. THANK YOU FOR YOUR HELP.
Without the Model Number I can only give you Basic instruction.
If your machine is Digital the best way to calibrate if find the manuel of your machine useing your Model number.
Some of the digital models : select bake and press and hold the up or down Temp button for 5 Sec to enter the calibration mode.
Some models require you do get the temp to over 400 deg befor you can enter the Calibration mode.
If your machine has a turn knob ... Take the knob off and see if there is a small screw in the center... This is the calibration screw.
Oct 05, 2010 | Magic Chef 9122 Gas Single Oven
Oven does not seem hot enough.
try a new thermostat or look for a manual what indecates a temperture adjustment switch
Mar 21, 2009 | Ovens
Self-Clean Option does nothing
IT TAKES 4 HOURS OR SO..DO YOU HAVE A TIMER
Dec 29, 2008 | Ovens
Pilot lights but the oven doesn't, when you turn it on
need brand of oven to help sorry
Nov 19, 2008 | Ovens
Stove won't go below 170
The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not work
I had same problem, My solution was to turn off the breaker switch off (disconnect the power) I kept it off for 1 minute turned it back on and it now flames.
Sep 08, 2007 | Maytag CWG3100A Gas Single Oven
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
