Question about Nintendo Wii Console
Wii wireless connection error 51330
Mac address was added to netgear router. tyrying to establish wii wireless connection. got error 51330.
  • 53 Answers
Get a new router
Posted on Feb 07, 2010
I need to connect my wii to internet. to watch netflix movies. never connected before to my wireless connection. getting error code 51330. please help me set up
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Apr 21, 2010 | Nintendo Wii Console
Cannot connect wii to wireless internet.getting error code 51330
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Apr 16, 2010 | Nintendo Wii Console
Trying to connect to wireless connection and getting error code 51330
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Dec 13, 2009 | Nintendo Wii Console
Cant get a wireless connection. error code is 51330
Set your router to Mixed Mode.
If it is set to G-Only it will not work.
Set the channel on your router to either 1 or 11
Both of these settings can be found in the wireless tab on a standard linksys router.
http://wiihacks.blogspot.com/2006/11/fix-for-wii-error-codes-51330-52030.html
Dec 02, 2009 | Nintendo Wii Console
Error code 51330 on the wii.it will not except my
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
Can not connect to the internet error code 51330 WII I have wireless connection in my home
I don't personally know how to solve this, but you could try some of the suggestions here.
Sep 09, 2009 | Nintendo Wii Console
Trying to connect my wii to the internet, am puttin my password in and its giving me an error code 51330
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Apr 14, 2009 | Nintendo Wii Console
Cant conect to internet
  • Wii Error Code 51300 - 51399
  • This error is caused by the Wii being unable to connect to the access point.
    To solve this error :
    Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
    If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
    If your router is using WPA encryption, the Wii is compatible with :
    WPA - PSK(TKIP)
    WPA - PSK(AES)
    WPA2 - PSK(AES)
    If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings
Dec 27, 2008 | Computers & Internet
Nintendo Wii Console Logo
211 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
