Question about GPS
Hi I have Innovatek 731 GPS and GPS-18 unit comes with them /When I go on Gps mode I have a message "No video signal" All connections are perfect/Is this something wrong with GPS box ore softwear?
  • 11,896 Answers
First thing I would do is update the software. You can get it from manufacture's website. Also shake the cables a bit to see if the are stretched or broken internally. If update doesn't help, then it is likely a faulty capacitor inside the unit.
Posted on Feb 08, 2010
On my Kenwood double din Excelron unit in my truck the unit operates perfectly the gps, dvd, phone, tuner, BUT when on sat alliteration radio XM su scriber it will play great of a while and just shut off....
Maybe you need to check your satellite antenna?? You said your GPS is working good? See if your GPS has a tool to check satellite connectivity and verify this. I find mine fails when I drive in a tunnel or are under covers of various kinds like a metal garage. Most GPSs have a tool to check on each satellite signal strength..
Sep 25, 2017 | Car Audio & Video
GPS 40 will not finish aquiring signal
make sure the gps have a full view of the sky. leave it in aquiring mode and let it sit there. My Emap took up to 35 mins once to reaquire the sats and get the updated info needed for position info.
if the unit has been off for a long time or moved a long distance from where it was last turned on, it can take a while for it to come back up.
Nov 06, 2009 | Garmin GPS
I need a manual for Innovatek GPS-721>I'm trying to install this radio in my Honda CR-V but I don't have the install manual to look at > I can't seem to find it on the net either> Can anyone help...
I have IN-721 Unit. The brake wire (Pink) you have to connect to a 12V - (negative) of your hand brake, to show picture on the screen only when the car is stopped & handbraked. If you want to see pictures while driving (not recommended because it´s really dangerous (I tried it)), simply connect the brake wire to a single 12V - constant wire.
The cell phone mute (orange), is to connect to a handsfree, to mute the radio when a call it´s coming on, but you don´t need a handsfree, because the radio (innovatek 721) has bluetooth to connect the mobile phone.
I think that this information could help you. If you have more problems, you can contact me Johnysince1986@hotmail.com
Sep 26, 2009 | Datalogic Cell Phones
Hi There, Just bought a new Nuvi 255, I was just driving to a destination and out of sudden, my GPS got a message mentioning, loss connection to sattelite. It stayed on for like 30 mins, till I reach my...
Unless you are driving in a dangerously remote area of some desert, or a large city, GPS units rarely lose signal. Chances are you have a defective unit, I'd contact Garmin support: Here.
Hope this has been of some help.
Jul 07, 2009 | Garmin nuvi 255W GPS Receiver
Innovatek in-731 gps (gps-18)
ho bisogno di un manuale d'uso in italiano per l'autoradio innovatek in-731gps come posso fare?
Jun 25, 2009 | Route 66 Route USA 2004 for Mac
Tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
Feb 11, 2009 | Tomtom GO 910 GPS Receiver
Continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
Dec 26, 2008 | Navman ICN510 GPS Receiver
"Waiting for a valid GPS Signal...."
the unit will only connect with the satelites out doors my man
Dec 22, 2008 | Tomtom ONE GPS Receiver
GPS maps for Innovatek 868
I need greek map for GPS maps for Innovatek 722 pleas help
Oct 21, 2008 | Car Audio & Video
MAP 76 locks up in normal mode after acquiring and starting to track, three to four minutes. Screen goes blank except for vertical stripe, no keys work. Have to pull batteries to turn off. Unit works...
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. Just so you'll know, I also did a software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS.
What you said does make sense. When you have your unit in simulator mode, the GPS receiver is turned off, so it is not receiving signals from the satellites. The strange signal from the WAAS satellite must be what has been messing things up. Good Luck!
Sep 26, 2008 | Garmin GPS Map 76 GPS Receiver
GPS Logo
231 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
