Problem for In Dash Receivers
Generic problem for all In Dash Receivers
1998 ford el xr6, need stereo wiring har...
i am putting a kenwood cd player and taking out my standard stereo out of my 1998 ford el xr6 and i need to know what the colours on the harness what r they, power earth etc? can anyone help please
Best Solution
posted on Feb 23, 2008
Rank: Guru
Rating: 86%, 7671 votes
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+
White/Purple
Switched 12V+
Black/Pink
Ground
Black/Green
Illumination
Blue/Black
Dimmer
n/a
Amplifier Remote
Blue
Antenna
Right Front
Front Speakers
6" x 8" Doors
Left Front (+)
Light Blue/White
Left Front (-)
Orange/Light Green
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
6" x 8" Rear Doors
Left Rear (+)
Tan/Yellow
Left Rear (-)
Gray/Light Blue
Right Rear (+)
Brown/Pink
Right Rear (-)
Orange/Red
1998 Ford Explorer Stereo Wiring
Constant 12V+
Light Green
Switched 12V+
Yellow/Black
Ground
Black
Illumination
Light Blue/Red
Dimmer
n/a
Antenna Trigger
Orange/Blue
Antenna
Right Front
Front Speakers
5" x 7" Doors
Left Front (+)
Orange/Light Green
Left Front (-)
Light Blue/White
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
5" x 7" Rear Door
Left Rear (+)
Gray/Light Blue
Left Rear (-)
Tan/Yellow
Right Rear (+)
Orange/Red
Right Rear (-)
Brown/Pink
Was this helpful?1 person thought this was helpful
Solution #2
Rank: Master
Rating: 79%, 12 votes
Yellow is A battery wire, goes straight to the battery to keep the memory in the cd player. Red goes to the ignition, tells your cd player to come on when you turn on your car. Orange is secondary power. Just tie it in with the red wire. Black is ground. The wires that have two of each, Purple,white,grey,and green are speaker wires. And the blue wire all by itself goes to your amp if you have one to the remote hole.
Solution #3
posted on Feb 26, 2008
Rank: Guru
Rating: 91%, 1193 votes
hehehe OI OI OI an XR6 is an Aussie built Falcon guys... not a truck or SUV careful revhead... better take care not to follow the wiring given above. I had a look, but could only find a paid copy of info
here
regards
Graeme
Comments:
Mar 01, 2008
- I would suggest ringing your local Ford dealership, and or contact an Car Installer, they may just give you the info you need. In fact, some Ford auto wreckers may be able to tell you also.
Solution #4
posted on Sep 24, 2008
Rank: Apprentice
Rating: 0%, 0 votes
Hey... not sure if anyone out there can help but I am after the XR6 turbo wiring diagram for the whole car.... just brought the engine etc and need to drop it into a new car.
Cheers!
Solution #5
Rank: Wiz
Rating: 84%, 59 votes
hello what ones are you after (car or stereo).let me know and i will get the code for you .
Popular Solutions for In Dash Receivers
Questions and Unsolved Problems for In Dash Receivers
when my subwoofer in the car is hooked up to my amp, it makes this pulse almost like a heartbeat...
(More)
when my subwoofer in the car is hooked up to my amp, it makes this pulse almost like a heartbeat with no sound. even when the rca leads are unplugged it makes the same pulse.
failure to receive an rf signal unless it's very close. on a cd4610
i installed my kenwood kdc-bt742u in my 1997 chrysler sebring and the radio plays fine, but when i...
(More)
i installed my kenwood kdc-bt742u in my 1997 chrysler sebring and the radio plays fine, but when i switch to cd, aux, usb, or bluetooth the sound doesnot come out through my speakers, how do i fix this?
getting my new stereo to connect with my amp
My Pioneer DEH-P47DH has recently started cycling on / off. I need to detach the face plate and wait...
(More)
My Pioneer DEH-P47DH has recently started cycling on / off. I need to detach the face plate and wait a couple minutes before reattaching to temporary stop the cycling. What can I do to permenantly stop the cycling?
