Question about Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
I HAVE A ETQ 1200 GENERATOR I NEED ON THE PART IT YPIE450050810 AND IN MY BOOK THAT
COME WITH MY 1200 THE NUMBER IS ETQ1200TG74
DESCRIPTION IGNITER THANK
I found that the switch wires under the gas tanks are pretty loose in their plugs going to the magneta.. Check all of your wireing under the gas tank for connection..I just put mine the shop and they told me that would run on ether but not on gas.. johndogfuzz@gmail.com
Posted on Jul 09, 2012
The pdf for this generator is available at easterntools.com
Posted on Feb 26, 2010
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
Further to my question about a weak spark on my etq 1200 ,would one of these be the problem, magneto,igniter ir capacitor?
A lot small ignition spark appears to be weak when they are not.
A couple things to check. make sure your spark arrestor is clean and your ignition timing is correct; otherwords, that the flywheel key is not sheared.
Nov 25, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
I have a etq 1200 generator that runs but doesnt have ac. what could be the problem?
Check that the GFI receptical is not tripped
Check that there are no blown fuses or tripped breakers
Verify that the engine is running at full RPM
If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Sep 04, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
Where is the muffler and exhaust on ETQ prtable generator?
The exhaust will be located on the output side of the cylinder manifold.
Sep 01, 2014 | Eastern Tools & Equipment ETQ Tg72k12 8250...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E Logo
1,329 people viewed this question
Top Eastern Electrical Supplies Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
ROBERT SIMPSON
Level 1 Expert
Are you an Eastern Electrical Supply Expert? Answer questions, earn points and help others
