Question about JVC HR-J692U S-VHS VCR
General connection from vcr to tv to satelite receiver
I have tried to hook up my jvc hr-j692u to my tv and my satelite receiver for some reason i cannot get a picture on playing a movie tape, i do however get the blue screen on my tv when i press play. I also get the text use cleaning cassette.I have also tried this and all through the cleaning cycle it still shows the "use cleaning cassette" My cleaning cassette is a Maxell vp-100 which has a video presentation while it cleans. This also does not view at this time.
  • 2 more comments
  • enforcerwbs Feb 08, 2010
    My tv is currently hooked directly to a rf box (which is needed for the audio/video wires to hook up with my dvd and ps2) in which my coaxial cable goes to the tv out section on the vcr. The ant in on the vcr is hooked into the satelite receiver directly. The tv only has the one port.
    Thank you. I just tried that feature about setting the vcr channel that seems to work when I tried playing a tape. The next test will be recording a show. I will keep you posted on the progress within the next half hour.Again thank you.
    Again I am writing to say thankyou I am pleased to inform you that my vcr problems seem to be over. After I finish posting I will close this request. Once again THANK YOU!!
    Thank you very much for your excellent assistance in the above matter.
  • 11,896 Answers
How do you have it hooked up? are you using RCA jacks or coaxil cable? If you are running satellite to vcr and vcr to tv, the vcr must be on the input/av channel.
If vcr is hooked up via RCA jacks, then tv must be on AV/Input channel
If vcr is hooked up to tv with coaxil cable, then tv must be on channel 3 or 4.
Also the vcr should have a vcr/tv button that you can press and should change some things for you.
Posted on Feb 08, 2010
  • Nate Stansfield
    Nate Stansfield Feb 08, 2010
    You are most welcome! And thank YOU for using Fixya!
How do you remove a jammed VCR cartridge from the player
easiest way is to remove the top of the unit and see what it holding it in. Usually a spring. There will be about 6 screws to get the top off.
Jun 01, 2014 | JVC HR-J692U S-VHS VCR
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
What kind of fuses are needed for JVC HR J692U VCR? Slow blow or fast acting? What termination style 1.25 a 250 volts.
I don't know what you mean on "termination style" but I can help you on the fuse type. If you have the dead fuse look inside and see if you can see a coil of wire. If you can it's a slow blow. If you haven't got it or it looks just like a broken wire or it's gone too much, then fit a fast blow. It won't make any difference. If it blows again after a new one is fitted then it's not because it's a fast blow. It means you have a short-circuited semiconductor somewhere causing it to blow.
Feb 14, 2011 | JVC HR-J692U S-VHS VCR
When I press the Menue button, I only get a blank screen not various options
unplug vcr for about 30sec and plug back in
this worked for me and my jvc vcr
good luck, roadstarman
Sep 06, 2010 | JVC HR-J692U S-VHS VCR
I have a new digital tv. I connected the out
If you are connected by component cables (Yellow/Red/White) from video/audio out, then you will need to select that input selection on your TV, normally AV3. I would also advise using a scart connector from your video to your TV, this would be AV1 on your TV & should then automatically switch over to the Video channel when you press the play button.
Jul 14, 2009 | JVC HR-J692U S-VHS VCR
How do I use my VCR with the DTV Converter Box that I had to get?
You only have three choices that I know of. The first two are a bit expensive though. 1) Buy a digital TV, then you could split your antenna cable to the TV and Converter box. Then use the converter box as the tuner for the VCR. 2) Buy a digital VCRand do the same thing using the converter box as the TV's tuner. or 3) Get a second Converter box and split the incoming cable between the two, using one for the TV and the other for the VCR. If you use any of these ideas, remember that You need to not have the VCR and the "new" tuner for the TV set to play on the same TV channel, and that you switch teh VCR out of VCR mode with the TV/VCR button, so that you get a clear signal on the other channel. If anyone has an easier solution, I too would like to know about it, seeing as I am in the same position and would like to avoid this problem as well.
Jan 02, 2009 | JVC HR-J692U S-VHS VCR
Toshiba vcr doesn't recoganize digital from sansui tv
is your vcr hooked up to your t.v. or through your cable or satelite box? if to t.v.,hook up through your cable or satelite receiver and this should solve your problem.... and should you need help with connecting cables to a receiver i can help you with that as well... i hope this was helpful...
Dec 16, 2008 | Sansui DFTC2000 20" TV
Vcr does not respond to tv/vcr button on remote
You will not know from looking at the VCR if it is in VCR mode or TV mode. This is more likely a TV issue of whether the TV is monitoring the VCR or not. Make sure you have the TV selected so that it is monitoring the VCR.
That VCR/TV button has caused more confusion for the average person than anything else.
Hope Ya Fix It!
Jan 22, 2008 | JVC HR-J692U S-VHS VCR
JVC HR-J692U S-VHS VCR Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
