Printer problems our old Raven PR-9101 doesn't work fast or well either. What driver should I need to solve this problem?
    Scholar:
  • 45 Answers
Hi landyrod,
The driver for your printer can be downloaded at
http://www.komputech.com/raven/down.htm
Download the KX-P1150 driver, as this printer uses the same driver as your PR9101 (ref.
http://www.komputech.com/raven/dmdrive.htm
Hope you find this information helpful in solving the problem
Kind regards and thanks for using the FixYa service
Posted on Feb 24, 2008
Samsung clp-365w crashes computer when trying to print
Uninstall the printer and reinstall it using the new driver. After removing the old driver and installing the new one, scan your computer with RadarSync so that you will know which drivers need some updating.
David
Apr 09, 2013 | Samsung CLP-365W Laser Printer - Color...
Tip
Troubleshooting Printer Spooling Problems
At its most basic definition a printer spooler retrieves the data for a requested print task and performs the required print even if it is not printing multiple print jobs. The simplest explanation, and where you should start, is in the task manager. Under "processes" in the task manager look for a file called spoolso.exe or spoolsv.exe; if these files are not present it simply means that the process has been stopped and needs to be restarted. This can be done by running "net start spooler" command. In the start menu bring click on the "run" option and type the command in the box prompt. Sometimes a faulty printer driver is the cause. This is hard to determine in any sort of certainty, but a simple reinstallation of the drives is simple and easy enough for virtually any user. Uninstall and reinstall your printer driver; if the printer works after the reinstallation you are safe and ready to print. The next step would be to check if old printer drivers are still installed on the computer. These can sometimes conflict with each other allowing an old print driver to be the spooler and not the proper driver for the current printer. Remember to clear the printer's queue before removing the old drivers. A last attempt at solving printer spooler problems is to manually delete the files in the printer driver. These will all be either .shd or .spl file types and are located in the temporary directories of your printer spooler subsystem. Whatever you do, do not delete the spooler subsystem app. This can cause even worse printer problems and in rare cases can cause major printer failures and errors. Should none of these work or solve the problem, it is in your best interest to seek a professional in the matter of solving the problem. Most printer spooler problems can be solved by the user in a few short steps.
on Sep 28, 2010 | Office Equipment & Supplies
I have install the driver through the Canon website for my windows 7, the Printer always show error and will not print my document. How do I solve this problem?
For canon you need to install the CAPT driver. Make sure you have done that. If it doesn't work try clearing your spooler file which may be causing problems. Look up guides to do that. It would be better if you could clarify what error it is.
Nov 03, 2012 | Canon PIXMA iP5000 InkJet Photo Printer
When i give a print command this error apears on the paper : pcl xl error subsystem:kernel error:illegaltag operator:0xfe
1st: turn off your printer, wait 5 minutes, turn on again. Try to print again and see if the problem is solved. If this doesn't work:
2nd: de-install your printer from your computer, download the latest driver for your operating system, install your printer again. And if this doesn't work, download the latest HP Laserjet generic driver and install it again.
You can find the drivers on the support page from HP, searching for the model printer that you have and select the driver for your operating system (windows xp, vista, 7..)
Aug 07, 2011 | HP LaserJet 1320n Printer
I need the driver for Olivetti PR 4RT, can someone help me? Thanks
Use this link, you must chose the language
http://drivers-free-download.com/drivers-olivetti-printer-4rt/
Jan 06, 2010 | Office Equipment & Supplies
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Sewing machine
While I don't have specific solution for your problem, I have a similar problem with my "Euro-Pro 9101. My needle keeps breaking and it hits the needle plate. The needle plate is now very rough. Does anyone know what the solution might be?
Jan 05, 2008 | Sewing Machines
Parallel incompetability
you can use a parallel card. buy it in a computer store and install, make sure you recieve driver CD when purchasing.
Feb 22, 2006 | Citizen Impact PR Matrix Printer
175 people viewed this question
k24674
jasbo
jasbo
