Agitator seems loose and not really turning - Washing Machines
    Sergeant:
    Champion:
  • 263 Answers
If it's a whirlpool, most likely agitator dogs went bad.
Whirlpool washer repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
Kenmore 70 series mod 110.24722300 the top part opf the agitator seems really wobbly, when spinning. is ther a bearing out or what? thanks
Does it agitate properly when in washing cycle? If it agitates "sloppily" there is a little kit you can buy to replace the agitator parts that get worn out. (they are called "dogs"). It doesn't cost much and is fairly easy to do.
The agitator my also just be loose. You can pry off the cap and tighten it up, but I suspect the dogs are worn.
Feb 14, 2011 | Washing Machines
The agitator seems loose on my Maytag top loading machine.. model LAT9206BAE it started this after one of my kids overloaded the machine.. works fine but makes a loud clanging noise while washing.. almost...
Use a 1/4 inch nut driver to tighten the set screw to the agitator shaft. It is about 3 inches up from the bottom of the agitator on the side of the agitator.
Dec 28, 2010 | Maytag Washing Machines
The agitator seems to "slip" and therefore does
There are a set of "teeth" in these agitators that where out. Pull the fabric softener dispenser off. Remove the screw holding the agitator in place and pull it up and out of the tub. Then you'll have to separate the agitator, just pull really hard, using a forked object like a tree (seriously). Then you will see the dog ears 4 of them get replacement parts install in reverse. It will work great, like new.
Oct 27, 2010 | Kenmore 24712 Top Load Washer
Ge whdrr418e4ww my agitator seems to have come loose
One stupid question on trying to get access to the nut to remove the agitator shaft. After I removed the fabric softener dispenser there appears to be a plastic cap between. I've tried everything I can to remove this piece of plastic so i can get access to bolt.. Am I missing something obvious?
Jun 11, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Model # is LSR8233EQO Top portion of the agitator seems loose and does not agitate properly?? Does is remove? It seems to unscrew??
you have to replace the dog's in the top ov the agitator.the part# ror this part is WPL80040462.the cost is $4.62.to replace the dog's you nead to remove the fabrick sofeiner assembly from the top of the agitator.next you nead to remove the top cap.now you nead to use a 7/16 socket to remove the bolt in the agitator.now you nead to grab the agitator at the bottom and pull it up.now yopu nead to seperate the top from the bottom.place the agitator on the floor,put a foot on both side's of the bottom of the agitator and pull up.now you the top portion of the agitator.turn top portion upside down and remove the cam.you will see the rubber dog's.replace the dog's and reverise the prossess.
Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore washer 100.92380200 upper agitator not turning
Just fixed mine. You will need an agitator repair kit. It comes with cover seal, bolt seal ratchet pieces and thrust plate for the bottom of upper agitator. Remove fabric cup and cover underneath. Remove bolt and upper agitator. Simple fix. New parts have instructions to repair. Get the correct model number and buy it from an appliance parts place. Around $20.00 retail.
Jun 15, 2009 | Kenmore Washing Machines
I have a Whirlpool Model# LSQ7030LQ0 washing machine. The washer is making a lot of noise and the agititator seems loose and is flopping around as it turns. If I grab on to the agitator I can stop it...
This "MAY" be an easy fix,
I have seen the main bolt that fixes the agitator to the drive shaft come loose.
If you can imagine the agitator as a cone, the top point of the agitator is a cap that should pull or clip off. If so, using a long extention shaft and a socket set, you should be able to tighten up the bolt.
Good luck and post back results
Jul 08, 2008 | Washing Machines
Agitator loose
Just reach down between the basket and the agitator, and lift really hard straight up. Be sure not to hit yourself in the head when it pops loose. GE agitators just snap on to the air-bell underneith. Be sure that bell isnt loose after you remove. Good Luck!!!!
Feb 02, 2008 | GE Profile Prodigy WPSE4200A
Loose agitator Maytag LAT2600AAE
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
Dec 17, 2007 | Whirlpool LSB6200PQ Top Load Washer
Agitator - is it working right?
there is slipping in the transmission. older machines used a pair of electrical solenoids to shift between spin and agitate. newer machines use the motor direction to engage the transmission for agitate and reverses for empty and spin. GE service phone: 1-800-848-7620
Sep 10, 2007 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
