I have a kenmore 110.92582220 and it only works in the heavy duty cycle,but it pops the breaker within 2 minutes of starting,i changed the motor and it worked for 2 months (in the heavy duty cycle only)before it started popping the breaker again.
  • jobos2000 Feb 08, 2010
    After changing the motor it worked for about 2 months just fine in the heavy duty cylcle. Do u still think is the timer?
    Sergeant:
    Champion:
  • 263 Answers
I would try a timer.
Sounds like there is a short in it.
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
Testimonial: "After changing the motor it worked for about 2 months just fine in the heavy duty cylcle. Do u still think is the timer? thank you"
  • 3 Answers
I have this washer and the mode switch (normal/heavy duty agitation switch) went bad, which stopped it mid-cycle. Replaced it and no more problems. Mine only pops a breaker if you have a heavy load in it that's off-balance during the spin cycle. This is a cheap fix, try it!
Posted on Nov 13, 2012
Why does it work in all cycles except heavy duty?
I think I answered this before. Get an electrician to check the motor windings etc to see if there is a problem under load.
Feb 17, 2016 | Washing Machines
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
Problem with a Lady Kenmore Model 902202
You might as well go ahead and replace the machine, the cost to repair this problem is going to shock you.
Jun 25, 2017 | Kenmore Washing Machines
Kenmore washer spins on gentle cycle but not on regular cycle
It sounds like you have a busted coupler. It's what connects the motor to the transmission. They will bust, letting the machine work unless it's under a load. It then spreads out and the motor shaft spins inside the coupler.
Nov 12, 2009 | Kenmore Washing Machines
I replaced the coupler in my Kenmore washer Ultra Care I Heavy Duty Series 80 (MOdel # 110 92582220). Simple enough, remove front/side panel. Pull motor off (only 2 eletrical disconnects), replace,...
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Kenmore Heavy Duty Dryer
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Feb 23, 2009 | Kenmore 63942 Dryer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 80 washer only works right on hevy duty load
CHECK SEE IF MOTOR IS SEIZED BY TIPPING MACHINE FORWARD AND SEE IF YOU CAN TURN THE MOTOR BY HAND. IF MOTOR TURNS FREELY , YOU HAVE A START CAPACITOR PROBLEM.
FXIT
Nov 20, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
