Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
Netgear wireless router
I have a Netgear wireless router and when I hook it up to my touchstone telephony modem model#TM602G/CT I can't get internet service, it worked fine when I had AT&T Internet service but since switching to comcast it won't work, how do i configure my router to the modem for internet service?
    Scholar:
  • 59 Answers
Most likely the router is not configured for dhcp or is not renewing to pull an address from your new provider. You will need to login to the router and check the WAN ip address settings. Choose dynamic ip address (it may be currently set for for static or another option based on your previous provider). Once you choose and save the settings, click to renew the WAN ip. If you were already set for DHCP and the address is correct, you may still have an issue with DNS,.. the DNS addresses may be incorrect or non existent. If you have doubts about DNS addresses,.. you may change them to 208.67.220.220 and 208.67.222.222 (opendns) and they will work with most providers (including comcast)
I hope this helps,.. if you need details,.. please leave a comment and I can supply more.
Posted on Feb 08, 2010
  • Sean Steiner Feb 08, 2010
    If you are not going to want to work on a resolution for your issue,.. please don't rate a solution as low, that you have not supplied any feedback for. You would not be asking questions here if you understood the nature of the issue. Please allow others to help you and if the solution does not fit,.. provide more info to get a solution that does,... no feedback or comments back from you does not help you get your issue taken care of. The proposed resolution was given to you free of charge and with the intent on helping you. If you do not need help here, then please dont waste volunteers time
I need the value for the network address property.
http://www.speedguide.net/routers/arris-touchstone-tm602g-voip-gateway-557
Oct 17, 2013 | Arris Touchstone Telephony Cable Modem...
We are currently running Comcast internet and phone through a Netgear Wireless-N 300 Router and an Arris TM502G Modem. Our phone service works fine, but the "Link" light isn't showing up for...
There's a reset button on the back of the modem. It'll power cycle it. That should work and if it doesn't make sure everything is connected and tightened.
Jul 29, 2011 | Arris Touchstone 450a (CM450) Modem
I just switched to TimeWarnerCable/Internet. How do I connect two PC's to the Aris TM602G Modem? Then How do I connect my Laptop? Bob
You connect the Aris to a wireless router with say 4 LAN ports.
You connect the PCs with LAN cables to the LAN ports on the wireless router and install a wireless card in the laptop if it does not have one.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 18, 2010 | Arris Touchstone 300a (CM300) Modem
Do I need a router in addition to the Arris tm602g ct provided by Comcast?
Yes, you will need a router the Touchstone® TM602G is only a modem. I recommend a Cisco-Linksys (#1 recommended router brand) like the E1000 Wireless- N Router (Walmart $59.00) with up to 300 Mbps data transfer rates; WPA/WPA2 (personal and enterprise) and SPI firewall protection; four 10/100 Mbps Ethernet ports. It will meet all your needs.
Thanks for choosing FixYa, If you find this helpful please vote and leave a comment.
Oct 14, 2010 | Computers & Internet
Is d-link 655 N wireless router compatible with Touchstone Telephony Modem TM602 that came with my cable/phone/internet service?thank you Joseph
Yes. D-LINK would be *STUPID* to try to market a router that is *NOT* compatible with *ALL* cable-modem (or DSL-modem) units.
Jun 24, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Bad relationship between Modem and Wireless Router.
Trying to understand the connections. It looks like the problem is FM-WR. Everything else works. Are you powering everything off when you move the router from one modem to the other?
Jun 20, 2009 | Arris Touchstone 450a (CM450) Modem
Need solution to Networking 2 comps thru an Arris tm602g/ct via a linksys 8 port switch, the seems to be no Usb connection on the modem
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
Mar 18, 2009 | Arris Touchstone 450a (CM450) Modem
I have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Feb 15, 2009 | Arris Touchstone 450a (CM450) Modem
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
239 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
