Question about Jenn-Air Ovens
PROBLEM IS: Jenn Air wall oven: JMW9527 1) Erratic oven temperature; also (unforturately) intermittant. 2) When calling for 325", we get an oven temp of 260" or less about half the time (auto-convect and not auto-convect both) using Amprobe meter with bulb thermocouple. 3) Amprobe meter also records a range from 280" to 360" with a 325" setting; "relay ON to "relay" OFF. Impossible to bake bread! What would be the normal range? 4) Readout on control panel increases and remains at 375" as if operating normally. 5)Last night I set 375" and used a handheld, laser dot non-contact thermometer and it registered at the top oven surface, 360" and on the bottom oven surface, 210". This morning when the oven was cool I set 375" again to feel the upper and lower elements; both got warm/hot---bottom first and then the top after a 15 sec delay. Note: I am trying to locate a service manual. Any help you can give me for repair ideas and manual purchases will be very appreciated. Thank you. Dean Johnson 509 548 8605
  • riksmal Feb 08, 2010
    Thank you. I need to completely read the manual and then will get back to you.
    Dean
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can download its repair manual from this link:
Jenn Air Wall Oven Repair Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    Thanks
    Rylee
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Older jenn air wall unit oven / turn knob
Yes, I just had same problem. The probe receptical is on the right inside wall of the oven. A little flapper door is secured by a single phillips screw. Remove this screw and the flapper door. Gently remove the receptical and its attached cable adapter. With your screw driver short the connector extension to the housing, just as the probe would. This should reset the meal temperature sensor. Try the bake and problem should be gone. If not permanently short this connection with a wire. You won't be able to use your probe, but the oven will work.
Feb 23, 2009 | Ovens
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
69 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
