Question about Viking VEDO276 Stainless_Steel Electric Double Oven
Power went out on double oven not circuit breaker any suggestions
    Sergeant:
    Champion:
  • 263 Answers
There is no fuse in this oven. So probably the display board then.
Viking oven repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
Why won't my double oven lights or power go on?
I think it would be a good idea to find the electric box and then:
1) find the circuit breaker or fuse that controls the oven.
That information is supposed to be written on the inside of the door of the electrical box.
2) Turn off the circuit breaker, or remove the fuse that is supposed to be the one.
3) Pull the oven out from it's place and try to get behind it to test (with an ohm meter or a multi-meter) and see if the unit is getting electricity at all.
Obviously, you will need to turn the breaker back on or screw in the fuse.
BE CAREFUL, THIS IS DANGEROUS STUFF YOU ARE DOING.
Sounds like you may need to reset the circuit breaker ( that means to turn it off and on a few times) or to replace the fuse.
God bless you in your efforts.
Sep 04, 2015 | Maytag MEW6627B Electric Double Oven
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
The power went off, when it came back on the oven time displayed. when we tried to turn on the oven the message feature not available came on
First try this: In your Household Circuit Panel, Turn the Circuit Breaker to the off position. Wait 30 Seconds and then turn it back on. Try to turn the oven on if it comes on you are in luck, if not look in your manual for first time set up instructions like setting the clock date and time, and go through the settings. Then try the oven again. If it comes on you are in luck.
Oct 15, 2014 | Whirlpool 24" Double Electric Built-In...
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
What size breaker and wire for this oven
Hello Sbilko,
I understand that you are tring to find a breaker and wire size for your GE JKP28 Double Oven. As I look up the specs on your oven I find that both ovens are rated at 30 amps. This requires you to use two thirty amp breakers one for each oven. The industry standard for Oklahoma requires that you use at least #10/2 wire for a 30 amp breaker. However, in some places it states that you can use #12/2 although I would not recommend using #12 gauge wire.
My suggestion to you is two 30 amp breakers and #10/2 gauge wire, this should be what will take care of the circuits and keep the wire form heating up.
Thank you for choosing FixYa.com
Justin
Mar 29, 2011 | GE JKP28 Electric Double Oven
The display panel is blank, and none of the buttons work. It had been working earlier in the day, but is no longer functioning. Is there a breaker button?
Hi, Check to see if there are any lights working, such as the ones that come on when you open the oven doors. If there is absolutely no power going to the unit, check the household circuit breaker panel that services the oven.
An oven works at 240 volts so the circuit breaker for it will be a double breaker, similar to the ones
electric water heaters or air conditioning units. It may have tripped. If it is tripped, then
the lever connecting the two sides of the breaker will not line up with other breaker switches in the
breaker panel. If that is the case, shut down the breaker completely and then after about 10 seconds,
turn it back on. If it will not stay on, there is an electrical problem in the circuit going to the oven or the oven itself. Hope this helps. Let me know if your need more help.
Best,
Mark
Dec 30, 2010 | KitchenAid Architect ® II KEBS208S...
Whirlpool Gold double oven - started beeping then all lights on the control panel went out. Reset the circuit breaker which makes the oven beep but still have no lights. Oven will not operate.
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
Sep 27, 2010 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
No power to the oven, is breaker external or somewhere on the oven?
Go to your breaker box or fuze box and look for a dual circuit breaker It should be labeled stove. Turn the breaker off If a fuze box there usually is a black plastic fuze holder labeled stove pull it out. Confirm at the stove a lack of power.
Dec 22, 2006 | Whirlpool RBD245PD Electric Double Oven
Viking VEDO276 Stainless_Steel Electric Double Oven Logo
197 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
