Question about AT&T Blackberry Curve 8300 Smartphone
How do i browse someone else's files via Bluetooth with the blackberry curve?
5 Suggested Answers
  • 10 Answers
SOURCE: Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Posted on Jan 28, 2009
kylemc1985
  • 12 Answers
SOURCE: I have a Blackberry Curve 8320. I purchased a
It may be the pairing code that you are using. Usually it is 123, 0000, 1111, 1234, or some other variation.
Make sure, also, that you are in pairing mode with the headset. If you can scan via bluetooth and detect the device, then it should be ready to pair.
Posted on Nov 02, 2009
Bajanguru
  • 7752 Answers
SOURCE: Blackberry Curve 8320 using Bluetooth.
try that see if that works
Posted on Feb 06, 2010
  • 84 Answers
SOURCE: i need help gettin my blackberry curve 8310 unlocked
unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8310 Unlock Code. Buy your unlock code from third party.
Posted on Oct 27, 2011
My blackberry 8520 stops reciving music halfway through when using bluetooth
firstly check to see if the format of the music you are sending is correct.
secondly make sure devices are both paired together
thirdly and most importantly make sure your blackberry device can receive the bluetooth connection. this is usually done by going to menu>media>select music> options and scroll down and select receive file via bluetooth or something to that effect.
blackberrys are not straight forward when it comes to sending files via bluetooth. hope this helps
Jun 11, 2011 | RIM BlackBerry Curve 8520 Smartphone
I bought my son a blackberry curve 8250 a few days ago. I cannot send any files to his new phone via bluetooth, even though the phones do pair with each other. Please help!
When you send over bluetooth on a blackberry and the handset pairs you need to select the file type you are send and be in the folder to received. Once in that folder you need to click the blackberry key and select received via bluetooth.
Feb 19, 2011 | RIM BlackBerry Bold Smartphone
A friend of mine passed a Blackberry Curve 8310 to me. When activated on a net work. I can only see the wap browser of the network. it still cuts my money for browsing after suscribing. Some one told me I...
You can only browse via the (chargeable) data service on your phone. It does not have wi-fi capability so you cannot browse for free via a network.
To obtain all other services other than the phone and regular browsing, you must subscribe to a BlackBerry data service via a mobile phone network and to do so requires a service contract.
Oct 06, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8520 unable to receive files transfered from other Mobile device through bluetooth. But able to transfer data to other mobiles through blue tooth
My Blackberry curve 8520 can send data via bluetooth but it unable to receive data from another bluetooth enabled device. please send me solution.
Jun 17, 2010 | RIM Holster For BlackBerry Curve 8520
How do i send pictures via bluetooth between a blackberry and non blackberry phone
just activate bluetooth on both phones then go to file u want to send via bluetooth, click on options then send viz bluetooth, click on search for new devices, select device name for phone u want to send file to then send.
Oct 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
8130 blackberry
go to media file and depending on what type of file (ringtones,pics etc) you can choose to recieve it bluetooth
Sep 05, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I can send files via my blackberry pearl 8110 bluetooth, but iam
1. Go to Media.
2. Hit the menu key (left of trackball) and select Explore.
3. Browse to the folder you want to store the file in.
5. Hit Menu key again and select "receive using bluetooth."
6. Send from the other phone.
You'll have to do this for each file individually.
Also make sure that you have paired with the device you are trying to receive from. In my limited experience i noticed that NOTHING transfers unless you are paired.
There is one more setting I would check, go to OPTIONS/SECURITY/GENERAL SETTINGS/make user the the
option for CONTENT PROTECTION is disabled.
Jul 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I can't receive files via bluetooth on my Blackberry Bold
When you want to receive a bluetooth file do the following:
1. Go to Media.
Jun 25, 2009 | RIM BlackBerry Bold Smartphone
I cannot bluetooth my contacts from my old sony ericsson 850i to my new blackberry 8320 even tho i have paired them,help please D.
unfortunately you cannot send address contacts via bluetooth with the blackberry.
you can send media files
go to the media folder you want to receive into and click the menu button and select "receive via bluetooth." Then send the file from the other phone. You have to do this for each file you send.
Good Luck and thanks for using FixYa
Jun 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
Okay,
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
71 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
