Question about Mitsubishi WS48511 48" Rear Projection Television
I have a ws48511 that has a red cast to the
Hello I have a ws48511 that has a red cast to the picture and i can't adjust the red x . thanks
  • 668 Answers
I think you are describing a convergence failure. Particularly if what you mean there is a red image/ghost around the video in the picture. If so, the Convergence IC, (STK393-110) will most likely need to be replaced. It is located on the center board, mounted to the large heat sink in the middle of the board. Be careful when removing the board. There are many screws securing the board to the chassis. Particularly on the back side of the heat sink.
I hope this helps,
Skyassoc
Posted on Feb 08, 2010
Testimonial: "It's alot more than I had befor, so it gives me somthing to check THANK's I will report resultes............. "
Why does my picture have a red cast the over all picture has red
Open the front panel until you see 3-6 knobs, adjust those knobs until you get the right picture.
Jul 19, 2010 | Hitachi 50UX57B 50" Rear Projection...
The top half of the screen is scrambling with wavy lines. Can this problem be fixed?
If you go into the customer menu and select convergence--instructions will appear on screen--select advanced and a grid of lines will appear.
If red or blue are skewed and will not adjust you have a convergence problem-If model ws48511 I have complete do it yourself instructions for this kind of fix.
YOU can post a photo here of what the picture looks like--I will attach one of a typical convergence problem--no two look the same but you will know if this is the problem you have.
SD TECH
Feb 17, 2010 | Mitsubishi WS48511 48" Rear Projection...
Red ghost in my ws48517
U can solders wright?Buy a convergence kit at Tv Repair World.com.To repair it ur self.Try U Tube.com for some sample for replacing some DLP tv IC convergence problems.
Feb 15, 2010 | Mitsubishi WS48511 48" Rear Projection...
Hi i have a mitsubishi ws48511 that the color
Normaly one colour tubes has problems , the others have opposite sintoms, better is go to repair store for checkup
Nov 29, 2009 | Mitsubishi WS48511 48" Rear Projection...
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
Red cast on all prints
Sounds crazy, but have you got the LM (light magenta) and M (magenta) tanks or inks mixed up?
Also - check the profiles, if you've got a colour profile set up, you may have applied it twice, which would make a magenta cast...
Dec 04, 2008 | Epson Stylus 1400 InkJet Photo Printer
Mitsubishi ws48511 convergence problem
Your model uses one convergence IC its a STK392-110 you need to replace that IC. You can get a replacement at the following link with free instalation instructions with pictures so you can do the repaair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Mitsubishi WS48511 48" Rear Projection Television Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
