Question about Welding Tools
We have just purchased a 2nd hand Lincoln Tractapac Welder in good working order, but the gauges have been obliterated over time. How can we get a visual of these gauges so we can replicate them?
  • lyn_watson6 Feb 08, 2010
    Thank you Michael34. Would you believe that this seller is in the same town as myself? Coincidence!
Click on this link below and then contact danmissa123 on ebay,
he has the same welder and can provide you with a copy of the gauges
http://cgi.ebay.com.au/Lincoln-Tractapac-with-16-Hp-Robin-engine_W0QQitemZ330387833214QQcmdZViewItemQQimsxZ20091217?IMSfp=TL0912171810001r13260
Posted on Feb 08, 2010
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Lincoln hd 140 barely sparks
Try switching the a,b,c,d back and forth a couple of times a corrosion builds up and causes a week contact so there isn't enough voltage to work . This has happened to me a couple of times . The first time the fan was running and I had no wire feed action and then a local repair guy told me that corrosion is very common with the portable Lincolns . You shouldn't even have to take it apart to clean it just switch it back and fourth and that does the trick. Good luck.
May 06, 2014 | Lincoln Electric Lincoln Easy MIG 140...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Whats making the fan on my welder not work
The fan motor has probably burnt out, i see this alot...make sure the connections are good....you can try putting 120v to it directly, if it doesnt run you need a new one...if it does then you need to check all your connections
Jul 22, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I have a lincoln stick welder . want to know what it's worth
I bought a good working Lincoln 225 about 2 years ago with the extended leads for $ 35.00 at a garage sale
Mar 06, 2010 | Tools & Hardware - Others
Where do I find a replacement cooling fan for a lincoln 225 stick welder?
I took my old one to Grainger and they ordered a new one that is 230V. Total cost of motor and fan $27.00
Jan 30, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have a Lincoln hady core wire fed welder, broken handle/trigger
if you call this number for Lincoln service they can fax or mail you that schmatic 1-216-481-8100
Aug 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have a Hobart 135 Handler wire feed welder that I purchased in 1993. The problem is when I turn the welder on, it runs just fine. However as soon as I squeeze the wire feed trigger to begin welding, the...
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
May 01, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
