I have a swingline electric stapler model 211xx with the clear cover. It won't staple and when I opened the staple tray it didn't open smoothly. I don't know how the previous owner did it but it looks like they somehow put staples in behind the staple barrier. Can I take this apart somehow to get those staples out. Does the cover come off. Do you have a manual for this model? I got it at a garage sale and am really bummed that I can't fix it.
  • dancing_ostr Feb 08, 2010
    I unscrewed the bottom screws. It just exposes some wires underneath. It has nothing to do with removing the clear plastic top.
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. I have been digging for 2 days through swingline and numerous other sites sites and now understand your quest for the manual.
After all the research to find you a manual the only thing I can recommend is that you visit a "Staples" Office Supply store and look for this item and ask for a copy of the user's manual or to borrow the manual to have it copied:
Item 642470 Model 21101 http://www.staples.com/office/supplies/StaplesSearch?errorUrl=zipcode&storeId=10001&searchkey=Swingline+Compact+Electric+Stapler&jspStoreDir=Staples&zipCode=92173&ts=1265655429363&langId=-1&catalogId=10051&ddkey=StaplesZipCodeAdd This is the best I can do for you from here. Kelly
Posted on Feb 08, 2010
    Brigadier General:
  • 3,917 Answers
You have to unscrew the four bottom screws to lift the cover.
Check this site to see how the electric stapler works…
http://www.youtube.com/watch?v=EjPoKWlxkMU
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Swingline 211xx Electric/Automatic Stapler
According to what I see that you have posted, it appears you have a Swingline stapler.
You have not mentioned why you posted this information.
Were you just telling us that you have one?
Mar 01, 2018 | Swingline Office Equipment & Supplies
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
Stapler (swingline 211xx) has jammed. It is electric. When I plug it in it make a very loud noise like it's trying to staple but nothing happens. When i press the release button on the top the stapler tray...
Turn the stapler over, remove the batteries, then remove the black pads and the four screwa under them. Take off the bottom cover and you will see the clear tabs of the cover sticking through the bottom plate. Pust them with a screwdriver toward the center of the stapler while squeezing the cover from the other side. Chances are that you will find the plunger that drives the staples is misaligned. Bend it gently forward or back until it moves without binding. Good Luck!
May 20, 2010 | Office Equipment & Supplies
Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
May 04, 2009 | Office Equipment & Supplies
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
305 people viewed this question
k24674
jasbo
jasbo
