Question about Philips 27PT6441 27" TV
Philips 27pt6441/37 I have a philips 27inch with chassis LO4.1u aa and it blew up a chip so i can not see the numbers to replace it. Any ideas how to figure it out? Thank you.
  • 1 more comment
  • Roger Hendrix Feb 23, 2008
    Call a distributor that sales parts like Fox International, ph#1-800-321-6992 or Vance Baldwin at 1-800-552-1431. One of these two distributors can look it up for you, make sure you brand name, model,and serial # of T.V.Look beside part and location available then they can look up the part for you. DOVECAT.
  • rsmock Feb 24, 2008
    The chip is an 8 leg and the number on the board is 7531 i seen a few other parts shorted and got them but i need the philips part number for this one so i can order it. Thanks again
  • rsmock Feb 25, 2008
    THANK YOU. I appreciate it very Much you been a big help.
    Scholar:
  • 90 Answers
Depending on which chip is blown, there could be something else that took it out. Fox International can tell you the part number if you can tell then the IC# that is printed on the pc board next to it or on the underside below it..The number above should work to contact Fox....
Posted on Feb 24, 2008
  • 48 Answers
What chip ? I have the service manual for this model and I should be able to help you.
Posted on Feb 23, 2008
  • Tony Harrison Feb 24, 2008
    Sorry ! whatever message you left me was either deleted by the administrators or for some reason I am unable to view it. It is a shame we are not allowed to post private email address, even by choice, because this will make things run much smoother. I want to help you privately, but I can't.
  • Tony Harrison Feb 25, 2008
    This is a standard vertical chip you can find it anywhere. Just call an electronics distributor like MCM Alectronics or MAT Electronics... and tell them you want vertical chip # TDA7531. That's all you have to say. And since your problem is in the vertical section, make sure to check capacitor C2465 10uf /100v it causes lots of vertical problems. It's better just to replace it anyway. Good luck.
    President:
  • 3,130 Answers
The only way now would be to get the service manual I'm afraid. Good Luck
  • Larry  Dillon
    Larry Dillon Feb 25, 2008
    OK I looked on a set that is close to your set. The IC marked 7531, and it is the control IC for the power supply? If so, there are some legs that are cut off it shows on this print as7531 is a TEA1620. I am not sure if this is the same as your set though.
Philips 42pf7320 10 has flashing led 13 times error code d5vl
your set is a 42pf7320/??. very inportant in you case. The chassis is a LC4.9E AA. error 13 relates to IC 7D03 (HDMI panel link receiver).
Jan 07, 2014 | Philips 42 in. Plasma TV
I need help with my philips projection tv
depending of model number the chassis needs to be tilted up so bottom of board is facing rear of set----resistors should be tested with a meter---both chips should be replaced and any of the resistors (most will be 5.6 ohm in value).
Not hard if you can get at and are able to unsolder the 18 pins on each of the 2 chips--the kit should have come with instructions?
Aug 27, 2012 | Televison & Video
Philips 32PT6441\37 will not turn on. Flashing
You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
Oct 17, 2009 | Philips 32PT6441/37 32" TV
Blown fuse, replaced it, other blown componets
http://music-electronics-forum.com/t9396/ THe link you need is in the thread. Just remember you will need test equipment, soldering skills, troubleshooting skills and direct replacement parts in the case of "chips".
Sep 01, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Replaced Philips 55pp9401 convergance and still has issues
Acording to my research and if you have the right model number this is an Hitachi chassis in this for some reason Where did you get the ic's from ? If there generic that could be your problem. You always want to buy them from Hitachi and they have a kit that comes with all the resisters . Don't get the cheep ones. Also there is no fluid problem with the Hitachi's. If your looking at the back of the set the IC's should be on the far right side and should have small color coded resisters to the left of them. If any of them don't have a bright color there bad. New IC's should be stk394-160. See if there is a chassis number and let me know.
May 19, 2009 | Philips 55PP9401 55" Rear Projection...
NEED URGERNT HELP!!!
Hey mate,
Let me know chassis number of TV as model number is not so helpful to me in Philips service manuals.
I do have few service manuals of Philips according to chassis numbers.
I can refer you a website where you can buy service manual with model number. Philips model and chassis game is still Puzzle for me.
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
I have a problem
You have a power supply problem. What is the chassis number of your set? Let me know the chassis and I may be able to help you out.
Mar 02, 2008 | Philips 60P8342 60" Rear Projection...
Picture issue with Philips 64" Big Screen
don't know if this is same problem or not but try this:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.keohi.com/keohihdtv/brandspecific/philips/philips_convergence_geometry.html
Dec 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Television
If your Philips TV chassis is L04.1U AA ( look at sticker on back )
the horiz driver chip kit is part # 483531057673................T.
Dec 05, 2007 | Televison & Video
Philips 27PT6441 27" TV Logo
128 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
