Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
It won't turn on, i have 2 batteries and both are charged. i have only had it for a month.
Iloilo city
try a different battery or use an external charger.... the battery could be faulty, or the camera charge function could be faulty.... a different battery will help you decide where the problem is.
Apr 05, 2014 | Nikon Cameras
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Acer aspire m5 won't charge
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-4740-4740g-4740z-4750-5335g-5335z-5340g-5542g-6495tg-8473g-8472t-tm5740-paypal.html
Apr 06, 2013 | Acer Aspire One PC Notebook
1992 mazda protege dx 4 dr won't start. Battery is only 2 months old. Makes a fast ticking sound from inside car similar to turn signal light out.
Hi Robin, As the battery is new and presumably not defective, I think you should suspect the soloniod fitted to the starter motor. If that component has become defective it will give the sound you're reporting. Depending on where you live in the world and the labour charges, you can have the contacter's replaced or the starter motor (if labour charges are high) Regards John
Jun 30, 2012 | Mazda Protege Cars & Trucks
Uniden battery will not charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Feb 04, 2012 | Uniden Cordless Phone
Been sitting for six months won" start
try your battery first most of the time thats the problem when you turn on your engine you should have lights if you dont then your battery is dead and that is the problem would reccomend you either charge the battery if that dosent work replace it but check first if lights are working a 6 month lie up would deaden your battery best of luck also any battery charger would do for the charge and also on a short term you can jump it from a car battery with the leads just to make sure its the battery also but do not try and charge from the car just check to make sure its the battery by doing this
Mar 16, 2011 | 2003 Honda CBR 600 RR
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
Battery doesn't charge
well there are 2 things here.
1.it could be the battery or 2 .it could be the charger.
best thing to do is take it to a dealerfor LG ask them to try a new battery, and also to find out if its the charger, .Your battery won`t be covered , but a charger will. Hope i helped.
Nov 15, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
