Question about HP PSC 2210 All-In-One InkJet Printer
Printer skips like its jamed but its not Printer says scanner malfuntion to restart printer I did it keep doing the same thing with the same trouble reading.
  • 1,675 Answers
How long have you had this all in one? if it is new, have you taken the LOCK off for the scanner?, has it been accidently been put on? check your manual to see, it should tell you about the transit lock or somthing simular,if not it sounds like the belt is slipping, has the printer been droped or bashed hard recently? it could have dissloged the belt for the drive or the motor for the drive belt could have warn teeth and it is slipping, just a couple of things to chek...hope this helps
Posted on Feb 07, 2010
Card does not appear to be communicating with a KodaK i840 scanner. How do I trouble shoot this?
the drivers for the?scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port?and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
May 18, 2011 | Kofax Adrenaline 1700s (EH-1700-1000)...
My printer(canon pixma mp190) keeps telling me that there is a paper jam, but i checked and there is no paper jammed, is it broken?
If i not paper in the printer,you must unzip the printer,the paper sensor is skipped.The paper sensor is under the scanner in the middle of printer.If the sensor id broken you need to replace,if the sensor is skipped try to put in the rigth position.Good luck!!!
Apr 09, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Kodak ESP-3 printer causes internet to stop working
Try installing the latest software from www.kodak.com/go/aiodownloads
If still the same issue, call Kodak tech support......for some advance trouble shooting or may be printer will be replaced
Jan 24, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Trying to use the scanner but no computer connection, press ok
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab33
Jul 08, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a officejet 6110 and when I turned it on the other day the scanner moves all the way to the right but never stops and sounds like a gear keeps slipping. Then a scanner failure appears on the screen...
Mr.Coiroj
This kind of problem creating from main dust only in Scanner Assambely so it must remove and make it clean; while you making clean use Soft Cloth to all the Glass to Clean; Do Not Apply Any thing in the Glass try it....
Jun 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My scanner keep on telling me the application is not in use , so
it is because of the corrupt scanner driver,,the printer scanning the corrupt driver of the scanner...
you need to uninstall existing printer driver and restart your computer ..after restart the computer install the printer driver again..
thanks for using FIXYA.
Hope it helps.
May 25, 2009 | HP Officejet 5610 All-In-One InkJet...
I am having trouble scanning with my hp printer.
You may try restarting your computer with your printer connected and turned off, or ensure that you choose officejet 5510 series and not 5510 twain in the scanner wizard. If this does not help, try reinstalling the printer from scratch.
Jan 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Scanner problems
Don't know if this helps but it's from the manual on lexmarks website.
Scanner Connection error 1 Disconnect the USB cable from the printer. 2 Reconnect the USB cable. 3 Turn the printer off. 4 Unplug the printer. 5 Plug the printer into an electrical outlet. 6 Turn the printer on. 7 Restart the computer.
Weird order of doing things but maybe that's what you have to do to get the scanner enabled again. Give it a try and see what happens.
Jan 04, 2009 | Lexmark X73 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
