Question about RCA P60921 60" Rear Projection Television
Sony 61" rear projection tv
Tv has no picture but it has sound.notice color bars or sort of at the bottom and top of screen
  • Jay Henderson
    Jay Henderson May 11, 2010
    Is the set HD Ready? also, What is the exact model # and serial #. Sounds as if signal processing board maybe going or is bad. Thankyou Jay
Is not hd ready,will need to send model and serial number later
Posted on Feb 22, 2008
Top and bottom of TV screen collapsing.
You may have a convergence problem (I will attach some typical photos).
When it does it go into menu and call up convergence grid--if lines skewed and colors mixed it is convergence. This model I think uses two of the STK-392-560 chips and both would have to be replaced if it is your problem.
I can provide more info if you find this is what you have.
May 29, 2012 | Sony KP-57WV700 57" Rear Projection HDTV
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
5 blinks on front screen no picture but sound
Go to Google understanding sonys blinking codes, then Go to this website they list parts for this TV Encompass Parts Distr. 1-800-638-3328 5 Blinks say to CK Q705,732,761 and on A board CK Q218,219,220 and they say you might just try turning up screen drives on your focus/screen block it has 3 on top 3 on bottom for screen drives to tubes
Dec 03, 2009 | Sony KP-61XBR300 61" Rear Projection...
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
My large screen projector type tv has a picture but there is groups of lined running across the screen from top to bottom. audio fine.
Sounds like hum bars if there white bars.Try disconnecting the ground outside at your cable hookups or sat etc.
Sep 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Rear projection picture problem on Sony 61" big screen tv
Sony had a problem with flickering, please confirm make and model number.
otherwise it sounds like a loose connection or bad convergance amp ic
Nov 13, 2006 | Sony KP-61HS10 61" Rear Projection...
RCA P60921 60" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
