Question about Princeton Digital EO 900f (White) 19 in.CRT Conventional Monitor
Monitor stuck in power saving mode - Princeton Digital EO 900f (White) 19 in.CRT Conventional Monitor
If the monitor goes into power saving mode as soon as you turn your computer on then maybe your graphics card is only half-way in and not secured properly. I would first recommend plugging in a different monitor if you have one, if it doesn't get any signal either then read on. I had this issue, basically a couple screws need to be put back in because they have fallen out. The graphics card was only partially plugged in and the computer would run but not "communicate" with the monitor. If you are unsure how to do this then I recommend taking a trip to your nearest IT shop, the job takes only about 1 minute so you should have your computer back quickly. Hope this helps,
David
Posted on Apr 16, 2010
Monitor went into power save mode and would not come back on
If your monitor is stuck in power save mode then first of all check all the power cables connected to monitor and your CPU.
After checking the connectors start the monitor if it does not come back from power save mode then lets move towards to second step.
2 . First unplug all the power cables to avoid power shock. After unplugging the power cables open the cabinet and look for the video card on *********** board.
Take the video card out and clean it with a normal eraser.Rub it on the golden pins and clean it.
Place it again at its place.
Close the cabinet and then start your monitor and your problem will be fixed.
Thanks for using Fixya.
Nov 13, 2010 | Computers & Internet
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
My flatron 1920P monitor is in power saving mode. How do I get it out of power saving mode?
It may stuck in the standby mode because it is not seeing the signal feeding it or there is problem in the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 29, 2009 | LG L1920P 19" LCD Monitor
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
My ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Nov 20, 2008 | Computers & Internet
My desktop pc has gone into power save mode
Turn the whole pc off then back on. If the LCD stays in power save then I would try a diffrent monitor on the PC. If that fixes it the the monitor is probably stuck in power save. Check www.lcdrpair.us for parts and instructions.
May 28, 2008 | Dell E173FP 17" LCD Monitor
Stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Princeton Digital EO 900f (White) 19 in.CRT Conventional Monitor Logo
94 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Sunday Ojelabi
Sunday Ojelabi
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
