Question about Philips 26PF5521D 26 in. HD-Ready LCD Television
26PFL5520D/50 DVT PROBLEM
When watching DVT THE SCREEN GOES BLUE WITH LINES ACROSS THE SDREEN
  • 476 Answers
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Posted on Feb 22, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
What causes horizontal lines across tv screen
The horizontal lines on the screen is a symptom of failing LCD panel, it will get more lines as time goes by.
Dec 12, 2010 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
H Lines on the left side of the screen
just in case you came across this - it is the light engine! $950 - thanks mits for complete junk
Oct 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Jul 24, 2008 | Philips 50PFP5332D 50 in. Plasma...
Blue lines across screen sony tv
blown fues on the G board, that should fix my problem
and or might need to replace stk392 convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Sony KP-46WT500 46" Rear Projection...
VS- 60705 Red,green,& blue lines all over screen.
sounds like your screen controls are too high? thay are behind the front cover 6 contols 3 for focus and 3 are screen the screen controls.
Apr 12, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Philips 26PF5521D 26 in. HD-Ready LCD Television Logo
259 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
