Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP can't change input modes
The Dell 2001FP started switching between input modes at random without any buttons being pushed. For a while I could change it back to the desired mode, but now it's stuck on one input mode (3: S-Video) and won't allow selection. The buttons on the control board make a nice click but will not change mode nor open menu.
At power-on the screen shows the Dell UltraSharp welcome message, but then goes blank. If I press the input mode button and the menu button together the screen shows me the message saying 'No input signal'. The screen never gives the floating 4-color self-test box.
Strangely, two input mode lights are illuminated (both 3: S-Video and 4:Composite) instead of just one as you'd expect
This happens regardless of whether or not it is connected to any video cables.
Any suggestions?
SOURCE: Dell UltraSharp 2001FP 20.1" LCD Monitor REPLACEMENT POWER CABLE
Here is what you need at a good priceLCD MONITOR LSE0202C2090 AC ADAPTERS WHOLESALE
Posted on Feb 05, 2008
  • 3940 Answers
SOURCE: LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Posted on Jun 08, 2008
c_robertson
  • 123 Answers
SOURCE: Dell 2001FP Monitor Problem
I have seen many of these. It appears the video processor board is dying or dead. You can replace the board or the monitor.
http://www.lcdrepair.us/2001fp-logic.html
This is the board. Not to hard to replace if you have some tech ability.
Posted on Apr 29, 2009
benwabnick
  • 2404 Answers
SOURCE: My Dell E176FPc monitor seems to be stuck in power
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Posted on Aug 04, 2009
  • 111 Answers
SOURCE: My Dell E207WFP LCD monitor has a blank screen
Hello!
For this issue you might reconsider focusing on your CPU Tower, the way you're describing the issue, the monitor losses it connection from the computer, therefore showing the "analog input..." This is a power saving feature of your monitor. This means that the monitor is no longer a signal from your computer. Possible points of failure for this one could be, PSU, memory, motherboard or add on video card if you have one installed, best approach i could suggest is to run diagnostics- if your still able to boot the computer - Try powering up the computer, when you see the Dell logo tap F12 several times until you see some options then look for diagnostics, then run it..(this is for a DELL pc) if it fails then a possible hardware issue, if your pc still have warranty, call in for help.
Hope it helps!
Posted on Apr 20, 2010
My Sceptre TV randomly changes input sources
i have a sceptre Lcd tv model x40 the red light is on but when you push the power button it will not come on
Dec 31, 2013 | Sceptre X405BV-FHD3 40 in. LCD HDTV
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My dell monitor wont display my pc image
Make sure you use the correct selection for your input (the leftmost silver button) to cycle through DVI-D, D-Sub, S-Video, and composite.If you are using this as a second monitor from your laptop, you have to activate the secon dmonitor using your keyboard or the operating system.
Sep 25, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
With Windows XP and Dell Latitude docking station, Dell 2001fp set to DVI, goes to Power Save mode and no display. It works fine with VGA input. It had been working fine for ~2 years.
Update Bios & Video Driver Also right click on my computer,go to properties,go under hardware,you can see hardware profiles,delete the dock profile (while the system is off the dock) & then dock & restart
Jan 08, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have a dell 2001fp. it is locked and can not access it to change it to vga, however it has a fine picture on dvi, any ideas
When you change to VGA, you have to change cables to a D-SUB cable. If you want to use S-VIdeo, you have to use an S-Video cable. You could actually have four different devices using the four different cables connected to the monitor one time, and change which one you are looking at by suing the button on the front panel to select the appropriate input.
Oct 11, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I locked my monitor and forget the code.can I reset to factory settings
You can also lock or unlock the OSD by pushing the Menu button for over 15 seconds. http://support.dell.com/support/edocs/monitors/2001fp/EN/controls.htm
Jun 05, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP
You rmonitor is likely fine, and the culprit is most probably your PC, specifically the graphics card. We won't rule out the monitor, however, until learning the specifics regarding your equipment - PC, graphics card, motherboard, and so forth, please.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 14, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001fp - Ramdom horz strips
Just had the same issue with the horizontal lines. In my case, too, turning off the monitor would make it go away for a while. called Dell, turned out it was still under warranty (3 years), got a replacement monitor the next day. Way to go Dell!
Dec 05, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP
Chances are the driver tabs inside from the panel to the internal controller board have failed. This is the actual controller board that the internal video card connects to (hidden under the silver cover on the back of the physical panel).
It is not a cheap repair, and it is normally best to source another panel, or just replace the monitor all together.
Oct 17, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Reference:
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Open Questions:
See all Dell UltraSharp 2001FP 20.1" LCD Monitor Questions
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
349 people viewed this question
Alun Cox
