Question about Logitech Harmony 890 LCD Remote Control
My 890 is no longer working correctly. It won't
My 890 is no longer working correctly. It won't turn on the power for my reciever and only works partially in turning on/off my TV
  • 3 Answers
I had a similar issue and only needed to "re-configue" the remote... Basically, just try plugging it back into a USB cord ( connected to your computer) and go to the original programming home page and click the "Update button." It will re-program your remote as if it was new.. Over time your Harmony may lose or forget the frequency of your various components. This happened to me. Also, make sure the remote has a full charge while you're programming it. Give it a try !
Posted on Mar 13, 2010
Clicking sound when you turn the tv on but won't work until a few minutes sometimes longer .
The clicking sound is an indication that the power supply is trying to start but is failing
Apr 16, 2013 | Televison & Video
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
After turning on Samsung TV with Logitech 890, the tv does not right away. I hear the tv trying to turn on but it takes about 30 seconds to do so.emote
This may not be a remote control problem. try turning on the tv directly from the tv and see if it takes longer than normal to power on. Sounds like a problem with the tv.
Dec 08, 2010 | Logitech Harmony 890 LCD Remote Control
Remote stopped working
Hey!
I have found when you are not able to control devices, a firmware update will sometimes fix the issue. If you do not know how to do a firmware update, please look at the following link:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=10747
If the firmware update does not work, you may have to learn the power commands from the original remotes. The following link shows how this is done:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=9603
I hope this helps!!!
-Kennedy
Jan 01, 2010 | Logitech Harmony 890 LCD Remote Control
Logitech harmony 890 fails to change channel or pull up guide. Will turn on television and adjust volume, but all other commands do not respond.
Did the behavior of your remote change or have you just started using the remote? If this is an initital setup, ensure that you have selected the correct model numbers and that your setup configuration is correct in the Logitech software. Many problems have been resolved by going back to the software configuration and making sure that all of the devices and mappings are correct. Assuming the programming is correct and things were working properly at one time and no longer are then you need to determine if the issue is a physical problem with the button activation (key presses are not making contact), or a software problem (corrupted programming). So here are some things to look
for:
When you press a key, do you see the 'transmit wave' icon appear at the top of the LCD screen? If so, then the remote is registering the key press. This means that the physical operation of the button is ok, so in this case, your issue is probably firmware/software related. You should update the remote's firmware and then re-load your settings. Both of these procedures are done using the Logitech software. If, after doing
a refresh of your firmware/software, there is still a problem, you can try mapping some of the hard keys to 'soft' keys on the LCD screen. So, instead of using the "Guide" button, you have a "Guide" option on the screen. The link below will explain the process for re-mapping button functions (it describes the process for the 880, but it should be the same for the 890). Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9796&p_created=1232640364&p_sid=1E1TzrCj&p_accessibility=0&p_redirect=&p_lva=3219&p_sp
Nov 17, 2009 | Logitech Harmony 890 Universal Remote
Cannot turn off closed captioning on my Sony Bravia using my Harmony 890 remote
If the setting provided by the Logitech data base for your Bravia model is not working use the original Sony remote to have the Logitech "learn" the correct code and assign it to a button or to a screen menu "button". The instructions for "learning" are on the Logitech web site when you log in to your account.
Jul 24, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 Pro dropped.....everything looks fine but it no longer controls system
You will have to open the unit up and repair whatever broke.
When this has happened in the past to less complex remotes, I have found that usually the oscillator chip has broken off of the circuit board, but whatever it is will have to be resoldered back into its original position.
If you have never worked on electronics before, you will have to take it to a repair shop, send it to the manufacturer, have a knowledgeable friend repair it or buy a new one.
Aug 12, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
85 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
